Samsung pn43d440a5dxza no backlight
  • crdz66
    • Nov 2012
    • 242
    Hi everyone.
    I have the vs and va voltage too low on my tv, but the tv still is working with no backlight. It is possible ???
    Sound is working fine.
    Re: Samsung pn43d440a5dxza no backlight
    How can the TV be working if you cannot see the panel glow? Plasma TVs do not have backlights. The panel may glow in operation in a dark room but in modern plasmas this black level can be very low.
    The most common fault on these is an X-main fault.
    • howardc64
      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
      by howardc64
      • Prior owner tried a replacement main board. No difference.
      • Samsung 2x red blinking standby LED = panel fault
      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
      07-19-2025, 10:54 PM
      09-07-2024, 05:50 AM
    • C152Heavy
      by C152Heavy
      Summary for TL-DR readers:
      • VCC pin (18) of PFC...
      01-11-2023, 02:53 PM
    • howardc64
      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
      by howardc64
      TV was fixed just after removing Samsung's rear snap cover.
      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
      Maybe PSU->backlight connector didn't have a good contact?...
      07-23-2025, 12:34 AM
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
