Samsung LN37A450C1DXZA LCD TV with Saturated Image
  • XRacerX
    • Apr 2014
    • 7
    I'm trying to repair a Samsung 37 inch LCD TV that has a saturated white/blue image. Please see the attachments... The original fault was the screen would gradually go red until it was completely saturated. At power-up it had a normal image but as the TV heated-up it would go red. When I received the TV I found it had a constantly white/blue saturated image.
    I removed the rear cover and checked the power supply for any signs of bad caps but didn't find anything unusual. I checked all the connections between the Main, T-Con, Power Supply and Inverter boards but didn't find anything wrong. Powered up the TV again and same problem.
    I then went into the service menu and did a reset. When the TV powered back on again the image was flipped 180. I went back into the service menu and changed the mirror setting to flip the image back the right way. I didn't take too much notice of the other default settings but I could have sworn they were set at "37" and now they are set at "40". It appears after the reset the main board is now set for a 40 inch. That seems really odd!
    Now it appears I cannot access the service menu. With reference to the attachments my original question was is this a main board issue or a T-Con board problem? But now I'm a bit stumped why I got values changing in the service menu following the reset, the image flipping upside down, and I appear to be locked out of the service menu.
    Any help would be greatly appreciated.
    Re: Samsung LN37A450C1DXZA LCD TV with Saturated Image
    I'll bet gamma chip fault. Post a picture of your T-con board. Fourth this week with similar fault.
    • XRacerX
      • Apr 2014
      • 7
      Thank you Tom.
      See pics of the T-Con board. It is part number T370XW02. I'd say the Gamma IC (U202) is an AS15-F if I'm reading the text on the chip correctly. So where do I make the Gamma voltage measurements? I'm guessing the 16 circular pads very close to the ribbon connector? Note there is a VGMA_REF pad near the crystal. Is this my -ve connection point for the DVM?
      I figured out why I couldn't access the service menu. I wasn't pushing the buttons on the remote fast enough. You have to be fairly quick pushing Mute-1-8-2. When it didn't work the first time I went slower thinking I wasn't hitting the buttons right. That just made it worse.
      Thanks again.
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        Don't mind me,made a nice circle around the chip,then saw you had it already figured out,lol....Couldn't delete this post
        Proud owner of dozens of broken TV's and many,many,many boards.
        Our website and passion:http://hollenhundshepherds.com/
          Check the voltages on the test points labelled VGAMA1 through VGAMA22, whichever are available.
          • XRacerX
            • Apr 2014
            • 7
            Thank you Tom.
            Here are the Gamma voltages:
            V1 = 15.6
            V2 = 15.6
            V6 = 15.8
            V7 = 15.6
            V8 = 15.6
            V10 = 15.8
            V11 = 15.8
            V12 = 8.1
            V13 = 6.3
            V15 = 8.7
            V16 = 5.2
            V17 = 5.0
            V21 = 0.5
            V22 = 0.4
            I entered the voltages into your spreadsheet and the result is fail. I've purchased a new Gamma IC off Ebay. I know a Technician with SMD soldering expertise and will ask him to replace the IC. I'll get back to you with the results...
            Thanks again.
            Also, I found a Russian website with a load of manuals. Elektro Tanya. I found the manual for the TV plus another manual for the T-Con board. Have you used this site?
            • drgears
              • Oct 2010
              • 25
              Just received a nice Samsung LN37A550P3F ,,,fired right up,,,good sound ,,pic is washed out,,,was looking for which component to start with,,,this post answered where to start....thanks guys....gbaum
                Check T-con fuse and gamma chip voltages.
                • drgears
                  • Oct 2010
                  • 25
                  Hi tom this one will probably just replace the board,,one site must have bought a truckload of damaged sets ,,has 10 boards available ,,price wasn't too bad 50.00 ,did a surface chip replacement on a vizio set ,,,not so good,,,fat fingers, old eyes,, well,,, need to get larger magnifying setup...
                  2 caps 1000mf /35 volt are bad,,,new ones coming from this site..replacing a total of 5......
                  • drgears
                    • Oct 2010
                    • 25
                    To update ,,,,new t-conn board installed,,,4 caps replaced,,,,,plays perfect!!!! total investment $63.00....really love "dumpster" brand TV's ,, best value for the $$$$.....
                      09-07-2024, 05:50 AM
                    • shlomim412
                      samsung ua55es6800 - no image
                      by shlomim412
                      hi
                      having problem with samsung ua55es6800
                      tv had backlight on, sound working - responds to the remote control but no image.
                      check tcon board - had 12v in but no other voltages present.
                      when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                      when leaving only left side connected - again no voltages and no image.
                      put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                      kept trying to block less pins on the left ribbon cable...
                      05-15-2024, 05:00 AM
                      LCD LED TV Service Menu Codes
                      ALL LCD LED TV SERVICE MENU CODES
                      Service Menu Code with Board Name
                      China Universal Board / Jumper Board Service Menu Code
                      Changhong Ruba Service Menu Code
                      Ecostar LED TV Service Menu Code
                      Orient LED TV Service Menu Code
                      Haier LED TV Service Menu Code
                      TCL LED TV Service Menu Code
                      Samsung LED TV Service Menu Code
                      LG LED TV Service Menu Code
                      Videocon LED TV Service Menu Code
                      Supra LED TV Service Menu Code
                      Toshiba LED TV Service Menu Code
                      Symphony LED TV Service Menu Code
                      Veste/ LED TV Service Menu Code...
                      10-31-2024, 03:58 AM
                      09-06-2024, 11:40 PM
