emerson LC320em93 2 blinks?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    when I try to power on its blinks green twice then goes back to red? anybody know of any common problems?
  • Nairolf
    Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
    by Nairolf
    I have a Samsung DM32D display.
    When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
    Here’s what I have tried so far:
    1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
    2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
    3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
    From these tests, I suspect the problem might be on the mainboard. Could anyone...
    08-24-2025, 03:47 AM
  • Andre Gilbert
    by Andre Gilbert
    11-20-2024, 08:52 PM
  • Taurus12
    Optiplex 3050 micro 2 blinks followed by 3 blinks issue
    by Taurus12
    Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
    I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
    i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
    Any recommendation on what I have to do next? Thanks in advance
    06-10-2025, 05:05 PM
  • J_T
    Operating frequency for motherboard common mode inductor/filter
    by J_T
    I have a question - I have replaced the PSU on my own iMac Pro. However, when removing the motherboard I knocked of a 120 OHM 30% 0.3A small surface mount common mode inductor/filter (~0602 size) in the ethernet circuit near the female RJ45 port.
    The closest match I can find on Mouser is 120 OHM common mode inductor at 100MHz - my question is this frequency correct for a motherboard? The schematic for the motherboard only provides '120 OHM 30% 0.3A' and the TDK part number does not return anything in google.
    Sorry, I am not experienced hence a basic question.
    01-04-2025, 05:54 AM
  • jchon
    Sony A1e 5-blinks help
    by jchon
    Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
    I found the service manual, which was critical to know where to probe.
    https://www.manualslib.com/manual/20...1e-Series.html
    With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
    Unfortunately the 5-blinks...
    06-28-2023, 11:52 AM
