Samsung le32a457
  • sordids999
    • May 2013
    • 2161
    Samsung le32a457
    Voltages seem fine got it today was told it works then won't turn on again and if they leave it a few days it works again
    Would it helping changing the caps to panasonic caps ?
    Re: Samsung le32a457
    If the PSU voltages are low when it stops, it could be a good idea. However main board failure is a lot more common on these.
    • sordids999
      • May 2013
      • 2161
      Ok ill change the caps anyway, so how can I check to see if the mainboard is ok ?
        If the PSU voltages are OK, then I suspect the main board is the most likely cause. Of course you should observe symptoms so check things like does the backlight go out? Video freeze? Sound go bad? Just narrow it down and see what the most likely cause of ALL of the faults is rather than any one particular fault.
        • sordids999
          • May 2013
          • 2161
          Right been running for ages turned off the tv tried to turn on again but the standby light flashing 24volts was 15 volts 12 volts was 8.5volts then eventually turned itself back on
            Hmm, well that would seem to point to a PSU problem; were those stable or jumping about?
            • sordids999
              • May 2013
              • 2161
              stable m8
                Can you confirm the BN44 number on the PSU.
                • sordids999
                  • May 2013
                  • 2161
                  Bn44-00214a
                    Replace CM808 the 18nF 630V capacitor. It has caused issues like this before.
                    CPC:
                    http://cpc.farnell.com/panasonic/ecq...v-5/dp/CA06936
                    Free delivery, don't abuse it by buying only one or they might stop offering that to you...
                    • sordids999
                      • May 2013
                      • 2161
                      shall i change the caps while im doing this they look fine to be fair ?
                        You might as well, given there are only a few on this board and they do fail from time to time.
                        edit: Whoops, that one is 50V... It will not work... I will try to find a better match...
                          Looks like CPC do NOT stock the req'd part which is annoying.
                          Please confirm value of CM808 in your board?
                          • sordids999
                            • May 2013
                            • 2161
                            i cant find a CM808 only CM809
                              Should be a small box capacitor about 1" long near the yellow transformer.
                              • sordids999
                                • May 2013
                                • 2161
                                Found it sorry it has 10n J 630v 389 MKP
                                  Are you sure that is not a dodgy 18n print? Hard to tell....
                                    It's amazing, I can't find the capacitor anywhere but some weird place in Greece, £5 for one cap is a bit steep... maybe have a look around in a few other places
                                    http://www.ebay.co.uk/itm/Wima-0-018...item4158c16f7d
                                    • sordids999
                                      • May 2013
                                      • 2161
                                      You might be right tom
                                        22nF is a lot easier to get hold of; if you want, you can try that first. Make sure it works on all modes and all brightnesses. 18nF could be penny pinching by Samsung or maybe it's important for matching the transformer, I do not know. The schematic says 18nF.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
