Samsung lt22a300
  • sordids999
    • May 2013
    • 2155
    Samsung lt22a300
    Totally dead can't even measure voltages fluctuating all over the place
    Any ideas
    Re: Samsung lt22a300
    Check for shorted diodes. I have one of these here, but no LED power cable or LVDS cable... good power board, screen and main board I believe.
    • sordids999
      • May 2013
      • 2155
      Found one shorted number SR315A SHS OFI
        I would try replacing that then. If you ever get a smashed one of these let me know if you have the ribbons/cables left over.
        • sordids999
          • May 2013
          • 2155
          Looking as we speak
            Actually just dug my power board out... same diode is bad.. hmm!
            I guess it's a common failure. Never checked the board properly, got the TV for about £10 off a friend of a friend whose "tech" had looked at it.
            • sordids999
              • May 2013
              • 2155
              what diode is it m8 looked on cpc but....
                3A 150V schottky,
                https://cdn.badcaps-static.com/pdfs/...ec4595154b.pdf
                CPC don't stock it (or a suitable replacement), closest is UF5402 but it will run hotter. Hard part to sub for. Might have to borrow a diode from another board.
                • sordids999
                  • May 2013
                  • 2155
                  hmmm got loads of boards but its finding the right one
                    Alternative, it's a bit of a bodge, but you could solder two readily found 100V diodes together, e.g.
                    http://cpc.farnell.com/vishay-genera...20This%20Range
                    Keep leads long for best heatsinking.
                    • sordids999
                      • May 2013
                      • 2155
                      ok ill try it cheers
                      • sordids999
                        • May 2013
                        • 2155
                        all done and working again just need to monitor now
                        • billy1
                          • Aug 2015
                          • 4
                          • netherlands
                          seems I have the same problem with my lt22a300 samsung.
                          I couldnt find a SR315A and tried you suggestion, but instead I used a IN5408 diode. Although the TV switched ON again, the diode didn't last long. I think the trick is the switch timing of the schottky, that is much faster than teh normal diode. I have to find a SR315 schottky to repeat the test. I'm pretty sure the SR315 is the problem.
                          • sordids999
                            • May 2013
                            • 2155
                            unless im wrong here but the IN5408 is 3A 1000V but you need a 3A 100V diode
                            this may work
                            http://www.ebay.co.uk/sch/i.html?_fr...%2F54&_sacat=0
                            • billy1
                              • Aug 2015
                              • 4
                              • netherlands
                              Thank for the adequate response.
                              Today I gave it a really Q&D try... . I happened to have a STPS30150CW dual schottky (TO-247). (I know 15Amps per diode is really overdone). For the test I only used one diode and had to do some changes on the PCB, but this solved the problem! IMHO it really needs to be a schottky in this SMPS, as is has to have a high switching capability. Still need to order the SR315.
                              • billy1
                                • Aug 2015
                                • 4
                                • netherlands
                                My solution still works. I think I leave it that way.
                                • zwarder
                                  • Oct 2013
                                  • 45
                                  • United Kingdom
                                  CM855 1200uF 10V can cause no picture flashing standby led
                                  • spiritfive
                                    • Jan 2024
                                    • 3
                                    • Italy
                                    I confirm, I've just replaced it with a 1500uF 16V capacitor (JB JRG) and tv went back to normal (used to have no power to the screen at all + standby led working normally)
                                      09-07-2024, 05:50 AM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
                                      Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 06:20 PM
