Parts for LG 42PJ550-UD
  • nuzpaper
    • Mar 2014
    Hello
    New to the forum and hoping I can get some advice. I used the search but came up empty. My LG 42PJ550 plasma has stopped working properly. No picture but have sound. I've looked around on the net it seems to be a common problem with Plasmas and is most likely that my Y-SUS board died.
    I am in Canada and the part number on the Y-SUS is EAX61332701. I found a U.S site that has part number EBR66607501 and seems to be the same as the Canadian part EAX61332701. My question is are they same product? It has proved very hard to find a site with the product in stock in Canada and at the same price as the U.S site I found. Less than half the price. Compared the pictures of the product and they look the same but still wondering if they are.
    Any advice?
    Mo
    Re: Parts for LG 42PJ550-UD
    You need to compare EBR number, not EAX, as one EAX number can code for many different EBR versions.
    • nuzpaper
      • Mar 2014
      Ok. Well here's what I get when I compare the pics of the them side by side. Very close with some small color differences
      http://www.aliexpress.com/item/Free-...414534500.html
      http://www.buyqual.com/eax61332701-l...ain-board.html
      • truep
        • Aug 2010
        • 373
        Just because they look alike means little. You should find the EBR number and match it. Check shopjimmy. The EBR number bay be on a sticker somewhere on the board.
        • PlasMatt
          LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
          by PlasMatt
          I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
          09-20-2025, 06:50 PM
        • Mark D
          Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
          by Mark D
          The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
          10-29-2024, 03:15 PM
        • legg
          LG 42PC3 buffer output doesn't follow YSUS
          by legg
          LG42PC3D -UD originally with green lamp but no display or audio.
          Owner says was working, then went 'pop'.
          All 5V caps bulging. replaced.
          All PSU output voltages within spec but -Vy is low on YSUS.
          One of three parallel fets between SUS_OUT and SUS_DN is zenering,
          eventually shorts DG. Replaced all 3 - -Vy now OK.
          Y scan buffer test point does not follow YSUS output below -50V
          Note: This unit seems to expect YSUS output to park at -Vy in between
          drive signal pattern periods. A replacement drive signal board confirms this....
          11-18-2021, 11:49 AM
        • 2elw
          SVOD4 PCB pictures + parts
          by 2elw
          Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
          STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
          GW1N-UV9UG169C6/I5 FPGA - Its a...
          07-04-2025, 12:23 PM
        • SurrealMustard
          What parts can be salvaged from a plasma with a damaged display panel?
          by SurrealMustard
          I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
          03-09-2025, 08:29 PM
