Samsung LE32C530F1W power supply is OK, the error is on the Main AV-Board BN94-02616H (BN41-01331B).
The A5V of power supply is OK ... all other voltage is missing. If I disconnect from the motherboard connector then inverter operates (the screen is bright).
Control panel is without function and LED is not lit, device no start and does not respond to the remote control .. is as dead.
The error is well known, only what is broken on the Main AV-Board?
See here:
http://www.ebay.co.uk/itm/BN41-01331...item258b8fba95
"Hi,
This listing is a board repair service to Samsung AV board numbered BN41- 01331B used in various LCD Samsung TVs. These boards are in both blue and green colours (see the picture)
The symptom of the fault is the set is dead and there is no light in the front, although there is 5V standby from power supply. If you pull out the connector between power supply and the main board backlights will come on.
You would need to post your faulty board to me.
I will fix it and return on the same day by recorded delivery. Any questions prior posting your faulty board-please don't hesitate to contact me. We are professional TVrepair service, and we are located inBelfast, Northern Ireland."
See here:
"Hi,
