SCART switching trouble
  • Tom41
    • Oct 2005
    • 336
    • England
    The main TV in my room is now only used to watch DVDs, VHSs and to play on my Wii games console; therefore it needs to be on AV mode all the time.
    However, it has a fault where the slightest vibration causes it to switch back to the RF tuner briefly, then switch back to AV. Just walking near the TV, or waving the Wii remote around can cause this switch - as you can imagine, it's really annoying with games!
    I've got a video of this happening with a game:
    http://tomsonic.dyndns.org:90/temp/tv_fault.avi
    Notice that when I shake the Wii remote about, the TV switches to tuner (which, since there's nothing connected, shows SIGNAL = 0) for a second before switching back to AV. The vibration also carries through to my tripod, but that's another story
    I believe the fault lies with the switching pin on the SCART connector; the voltage is briefly interrupted and causes it to switch back and forth. I tried a different SCART lead and that didn't help, so I'm assuming it's the socket.
    It could well be a dry or loose solder joint on the socket itself. This particular TV, when opened up, is very hard to get at the base of the board where all the solder pads are - so is there some way I could bodge a repair? Perhaps feed a switching voltage into the TV constantly, so it's not affected by the faulty socket?
    Perhaps I could cut the wire that carries the AV switch signal in the SCART plug, then select AV manually with the remote every time I turn it on. But I don't know which pin carries the signal!
    Any more suggestions?
    You know there's something wrong when you open your PC and it has vented Rubycons...
    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-06-2024, 05:30 AM
    by sam_sam_sam
    03-31-2024, 02:12 PM
  • Natob82
    Micro Momentary Push Switch?
    by Natob82
    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
    12-21-2022, 05:22 AM
  • SluggerB
    Help making a switch work the opposite way with a relay
    by SluggerB
    I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
    I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
    It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
    02-07-2025, 07:57 PM
    Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
    by sam_sam_sam
    Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
    ( needs more cam circuits for the machine to work correctly again )
    https://www.ebay.com/itm/275321870186
    To
    3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
    ( not 4 positions but the right amount of cams circuits )
    https://www.ebay.com/itm/274660439950
    I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
    03-18-2023, 05:12 PM
