Samsung LE40R87BD
  • ronhayes
    TV Engineer
    • Mar 2014
    • 458
    Re: Samsung LE40R87BD
    Yes it does ! put handle of tester screw driver near each HV cable and it lit up then put it near all connectors on inverter board and they also lit it up, So would this confirm that tubes and inverter are all good or just confirming inverter is good but tubes may be faulty ?
    And that the fault is 100% power board ?
      Yes one of those HV screwdrivers can be used. BUT!! Do not ever use them for their intended purpose - see here:
      https://www.youtube.com/watch?v=AGXQNLq19FQ
      Unfortunately the result is inconclusive. The outputs could be working, but be too low. This is a very rare fault. I have to say, I have never seen a TV do this and not shut down. Usually the inverter circuit would detect a fault. The fact that it isn't would indicate to me it's more likely around the PSU output.
      • ronhayes
        TV Engineer
        • Mar 2014
        • 458
        Ok thank you Tom
        Think I will do some more checks on the power supply !
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
          09-07-2024, 05:50 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
