usp440m-42lp psu
  • Alastair E
    replied
    Re: usp440m-42lp psu
    OK--Thats one of the 5V lines--there's usually a few. Some will be powered, some not when in standby.
    Check 'em all, post results and the names/references of 'em pref with a pic of the plug you measured them at...
  • joehezzer
    replied
    Originally posted by Alastair E
    Firstly, with set unplugged, use your meter to check the fuses on Y-SUS and Z-SUS. Any blown and there's a short somewhere....
    they are all ok checked them earlier (fuses), i disconnected the boards y-sus z-sus one at a time to see if it turned on still nothing
  • joehezzer
    replied
    just looking for the 5v stby point, i can see 5v ctl
  • Alastair E
    replied
    Thing is--The V7 is pretty long in the tooth now, and only a 480p res, so not worth spending any real dosh on--certainly not investing say 50 quid in a PSU!
    A few tests will determine whats what...
    Then check the resistance from each fuse--to chassis metalwork. This should initially 'kick' or read for say half a second as the caps charge, then read a pretty high resistance.
  • joehezzer
    replied
    Ok will have a look tomorrow when I finish work. The chap I got it off said they had a power cut and it never came back on
  • Alastair E
    replied
    Ha! A V7!
    First plasma I ever potched with was a V7. Still got an alleged brand-new IPM for one kicking round somewhere....
    10-1 that PSU is OK. You'll need to check for 5V stdby supply first before going any further.
  • joehezzer
    replied
    Pics of chassis....?
    --I'll bet that PSU is OK from experience....
    model number pdp42tv006
  • joehezzer
    replied
    Originally posted by tom66
    Fuse is good?
    Early Bush plasma - probably early LG panel - 42V5/V6/V7? If so watch out for sparklies/maldischarge fault.
    I'd check input fuse and bridge rectifier for DC.
    yep you're right tom
  • joehezzer
    replied
    bridge rectifiers tested good, i will get more pics later
  • Alastair E
    replied
  • joehezzer
    replied
    Fuse is good?
    fuses are good, i will check the bridge rectifiers as soon as i can
    replied
    Fuse is good?
  • joehezzer
    replied
    i have checked the voltage on the points marked in yellow, nothing at all no standby light nothing. i have done a minimal amount of checks as i was just going to replace psu. there is a big blue block (relay i think ) found a post somewhere saying it might be that, its a bush 42" PLASMA, i do not have model number as of yet
  • Alastair E
    replied
    What tests have you done on it?
    Stby 5v present?
    Have you tried turning the PSU on by sending the PS-On, Vs-On, etc to it?
    What set? PSU may well be fine--could be a Set fault and nothing to do with the PSU at all!
  • joehezzer
    replied
    anybody know of anywhere i could get one or is interested in trading !!!
  • joehezzer
    started a topic usp440m-42lp psu
    usp440m-42lp psu
    Hi all does anybody have any experience with the said psu, picked up a 42inch plasma the other day, the psu has no power and am struggling to find a replacement cheers
  • dicky96
    Need to buy buck regulator MP2329CGG but struggling to find supplier
    by dicky96
    Hi guys
    I need one of these MP2329CGG for a repair job. It's a 24V 6.5A buck converter. But I have not been able to find a supplier who has that component.
    Actually I would buy a few as I always think if I found one faulty already I will probably find more in the future
    I had one supplier on Aliexpress who gave me a price $2 each, but I have been waiting some days since I asked for shipping price and they don't reply
    Does anyone know where I can buy that part in small quantity (let's say 5 of them), or any equivalent I could use? it supplies the Standby...
    03-05-2021, 08:44 AM
  • Faileng
    Struggling with a soldering job, need help.
    by Faileng
    Hello, although I've never been formally taught soldering techniques, etc... I've not really run into too much trouble soldering, with the exception of this job...
    I've got a supposed blown transistor on my fuel pump on my car and I'm trying to replace it. It's a gel encased circuit booard with very fine connections. Please see photo uploaded.
    I've cleaned up the area that I'm working on with alcohol scraped off the wires, etc..
    I cannot get any solder to now stick any of the connections, I've used various grades of solder and flux combination, nothing...
    02-06-2020, 02:07 PM
  • rockman97
    Need BIOS dump for ASROCK FM2A55M-VG3
    by rockman97
    Hello guys,
    I am struggling to find bios BIN file for ASROCK FM2A55M-VG3 (i had the normal VG3 not the VG3+)
    When i download from official website, and put that in EZP2019+ programmer software it says ''FILE LENGHT, BEYOND RANGE OR IT WILL BE IGNORED''
    That means that file i downloaded is larger than chip says, even tho chip is 8mb and file is 8mb.
    It has the Winbond 25Q64FVAIQ chip what i need to select the prgoram?
    I created a backup but when i rewrite its not work.
    Yesterday, 04:31 PM
  • Rickkap
    Help in identifying a component- ASUS ROG G634J
    by Rickkap
    I have an ASUS ROG motherboard and it has a shorted/burnt component which I'm struggling to find or identify.
    Any information would be greatly appreciated.
    If anyone has the schematics/boardview that would really help....
    Yesterday, 01:24 AM
  • Dreigas
    Laptop, Bios and some phones schematic database
    by Dreigas
    About a year ago, I was struggling to find schematics whenever I needed them. As a programmer, I saw an opportunity and wrote a few scripts to automatically gather a large database of them. Today, I've decided to share it with everyone, because good things should be accessible to all.
    What's included? Over 14,000 laptop schematics, as well as some BIOS files, and about 1,000 phone schematics.
    Everything is compressed in a RAR format and is over 140 GB. (Since it's such a large file, your browser might show a warning.)
    I plan to host the...
    08-20-2025, 09:58 AM
