LG 42" Plasma Display Model 42PT350R
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Hello Guys,
    I am not familiar at all with plasma tv's but i tried my luck anyway since business is so bad. We gotta try, right?
    Anyway, the original problem was a tv clicking and not starting due to a short circuit on the Z-Sustain board (on the right side from the rear).
    I found two transistors shorted (30F123) and changed the gate driver ic's as well. I think they were FAN73711. I soldered for dry joint on power supply, Y-Sustain and Z-sustain. Started up the TV and the short was gone so i had an image but.....
    Lots of colorful speckles on the image and also there seems to be "mal discharge". I keep seeing the previous image on the new image.
    I had color bars been generated via my color bar generator tester and when i went to a white image i could still see the bars bleeding through in the image.
    The white raster is also not right its more patchy and gray. Images to follow
  • angelos
    • Dec 2012
    • 573
    • South Africa
    This is the board layout.
    • angelos
      • Dec 2012
      • 573
      • South Africa
Name:	Panel Voltages.jpg
ID:	3264935 Close ups of boards
      • angelos
        • Dec 2012
        • 573
        • South Africa
        Some pictures of the problem
        The white raster is gray and it has the color bars of the previous image
        • angelos
          • Dec 2012
          • 573
          • South Africa
          I just don't know where to measure Vscan and what to use as ground reference. Is chassis ground ok?
          Vy is ok, Vs and Va is according to panel sticker, some other voltages on Y-SUS also ok according to panel sticker. I think it was a 200V and a 120V. I am at home now so i am recalling from memory. I do have an oscilloscope but don't know what to measure.
          on Y-SUS +5VF and +15VF measure weird with chassis ground as reference. its not 5V and 15V.
          I suspect something is wrong on this board, not sure.
          I did take oscillogram images of the waveform on the buffer board and it looks right, not sure what the peak voltages must be.
          Specific question might narrow this down.🤭
          • angelos
            • Dec 2012
            • 573
            • South Africa
            There was a +15V rail that measured 18.2V somewhere there.
              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:20 PM
            • Jaime Morillo
              Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
              by Jaime Morillo
              Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
              The TV was stuck on the logo and I couldn't access the update menu.
              I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
              The image result was good, but the image is inverted.
              The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
              Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
              08-18-2025, 11:38 AM
            • piershs
              Toshiba plasma 50WP16 wierd double image fault
              by piershs
              My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
              Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
              • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
              • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
              08-01-2020, 01:07 PM
            • x_orange90_x
              TCL 50S535 bad tcon or panel issue?
              by x_orange90_x
              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
              03-29-2025, 11:02 PM
              HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
              09-06-2024, 10:56 AM
