Samsung UE55H8000SZ with TCON BN41-02112A
  • michdundee
    • Sep 2023
    • 19
    • Italia
    I'm facing a issue... hope you could help me. I have a T-CON board BN41-02112A from Samsung 55inch Curve TV.
    I have just only 2 status blue LEDs ON since LED3 is off. I have tried to test some test points but VON is NOT OK very close to 0V. Is there someone that can help me on the debugging the issue? I'm supplying the board from an external 12V voltage source. ​
    Thank you in advance.
    BR,
    Michele
  • lotas
    • Jan 2016
    • 4789
    • Russia
    Without the panel, 3 led will not light up.
    • CapLeaker
      Leaking Member
      • 8340
      And I don’t think you can troubleshoot anything much with out having all of the TV.
      • michdundee
        • Sep 2023
        • 19
        • Italia
        Hi all, thank you for the quick reply. With the TCON connected to the mainboard and the panel the LED3 is not turning on too and I have no sound and no picture just backlights. from where can I start to debug the issue?
        • lotas
          • Jan 2016
          • 4789
          • Russia
          Place a jumper on T-con F_R< --------->F_L, disconnect the cables going to the panel one by one and check the non-working side.
          • michdundee
            • Sep 2023
            • 19
            • Italia
            Hi Iotas, what do you mean for "place a jumper" F_R <---> F_L? thank you in advance
            • lotas
              • Jan 2016
              • 4789
              • Russia
              F_R <---> F_LClick image for larger version
              • bohaboha
                • Nov 2012
                • 1017
                • sweden
                why are you supplying the board from an external 12V voltage source. is the power board not working?
                and please upload pictures of the set and all the boards
                • michdundee
                  • Sep 2023
                  • 19
                  • Italia
                  Hi Iotas, what is causing the short between F_L with F_R? I will try it for sure.
                  • michdundee
                    • Sep 2023
                    • 19
                    • Italia
                    Hi Bohaboha, trying to supply the board for a raw sanity check. I was expecting to have LED3 on too (the boost section) but I guess there are firmware dependencies. Another detail: when I try to turn on the TV the power state red LED is blinking slowly 4 times.
                    • michdundee
                      • Sep 2023
                      • 19
                      • Italia
                      the other boards attached
                      • lotas
                        • Jan 2016
                        • 4789
                        • Russia
                        F_L and F_R are feedback. If you disconnect any cable (left or right), then the panel and t-con feedback is disrupted.
                        • michdundee
                          • Sep 2023
                          • 19
                          • Italia
                          Hi Iotas, ok I see thank you for the explanation.
                          • Diah
                            • Feb 2013
                            • 6478
                            so yours main boards try to boot but it couldn't... you need to test first PS_ON signal >3V on the PSU sockets first.., if yes you have and other V PSU send back.. then you have issue at the panel.
                            • michdundee
                              • Sep 2023
                              • 19
                              • Italia
                              Hi Diah, I have a stable 3.3V on PS_ON. is that ok?
                              • Diah
                                • Feb 2013
                                • 6478
                                yes its ok, but what about other V the PSU generated... list them over here with pin name
                                • michdundee
                                  • Sep 2023
                                  • 19
                                  • Italia
                                  see attached picture too
                                  2 3.26V 1 0V
                                  4 3.26V 3 3.25V
                                  6 3.26V 5 0V
                                  8 3.07V 7 12.83V
                                  10 3.16V 9 12.83V
                                  12 4.81V 11 12.83V
                                  14 3.3V 13 12.83V
                                  16 0V 15 12.83V
                                  18 0V 17 0V
                                  20 12.83V 19 12.83V
                                  22 0V 21 12.83V
                                  • lotas
                                    • Jan 2016
                                    • 4789
                                    • Russia
                                    2 3.26V 1 0V
                                    4 3.26V 3 3.25V
                                    6 3.26V 5 0V
                                    8 3.07V 7 12.83V
                                    10 3.16V 9 12.83V
                                    12 4.81V 11 12.83V
                                    14 3.3V 13 12.83V
                                    16 0V 15 12.83V
                                    18 0V 17 0V
                                    20 12.83V 19 12.83V
                                    22 0V 21 12.83V
                                    Why do you need these voltages now, your 3 LED on the t-con is not lit, put a jumper and check your panel by disconnecting different cables.
                                    • michdundee
                                      • Sep 2023
                                      • 19
                                      • Italia
                                      I will do it in the next days thank you. I will let you know the outcome of the test.
                                      Diah was asking the table above and I have provided the list with related values.
                                      • lotas
                                        • Jan 2016
                                        • 4789
                                        • Russia
                                        If there were problems with the power supply, then the backlight would not work and 1 LED (12v is the norm) on the T-con would not light up.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
