samsung le40b650t2 flickering standby led
  • comptek
    • Aug 2013
    • 606
    • uk
    hi there i am pulling my hair out well whats left of it
    ref le40b650t2 i went to customers house to repair his tv, it worked out that it needed a replacement main board, as the user had plugged in his laptop connected through a faulty hdmi cable with a bent pin and the tv turned off straight away it had knocked out the main board Which caused it not to switch on
    1) replaced main board (aresnal-chelsea) BN41-01167B(MP1.1)
    result tv switched on but standby LED flickering constantly
    2) orderd another main board same as above (just incase)
    result same fault flickering standby led..
    3) tested power supply all ok but ordered another just incase
    result still flickering standby led
    4) unplugged tcon
    result standby LED still flickering..
    (overview) cant press any touch panel buttons, remote works to the extenet of vol up/down channel up/down you have to keep the power button on the remote for a good few seconds before it powers off, no other function works inc source etc
    i first thought there was another remote in the room but i shielded the infa/red reciever and led still flickers stroke pulses
    could it be the touch switch assembly p/n BN41-01187A
    any help is much appreciated
    regards
    Gary
    Re: samsung le40b650t2 flickering standby led
    Try cleaning touch pads on that board - could be dirt contamination causing erroneous touches.
    • comptek
      • Aug 2013
      • 606
      • uk
      Hi Tom66 Thank you will try that and get back to you
      would you say it points to the touchpad then in your opinion ?
      many thanks
      Gary
      • comptek
        • Aug 2013
        • 606
        • uk
        hi Tom just to make sure youre aware im not sure you can clean them as they are foam pads covered in that earthing metalic material
        thanks in advance
          Yes I've had this issue before.
          If they're anything like the ones on Vestel sets they are bare PCB with capacitive pads. They detect slight change in capacitance by finger. Any contamination between the PCB and the external plastic can cause a failure to sense or erroneous touch detect.
          • comptek
            • Aug 2013
            • 606
            • uk
            ok thank you Tom i will look into it
            many thanks
            • comptek
              • Aug 2013
              • 606
              • uk
              hi Tom66 and everyone problem solved!
              it seems the guy when he plugged in his laptop with a faulty hdmi plug he took out his main board and the switch panel (resistance pad) type
              replace the pad assembley it now works with the replacement and no flickering standby light ..............
              hes next problem his virgin tivo box isnt working it comes up "starting up" and after 5 mins "no signal" still shows on the screen,
              but thats not my problem
              thanks for all your help!
              regards
              Gary
                These TIVOs kill so many TVs! It is possibly surge damage from Virgin TiVo... think cable TV is a lot more vulnerable than satellite.
                • comptek
                  • Aug 2013
                  • 606
                  • uk
                  i think youre right there tom
                  thanks again
                    09-07-2024, 05:50 AM
                  • tvguy12012012120
                    by tvguy12012012120
                    02-07-2025, 05:13 PM
                  • ChristianBr01
                    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                    by ChristianBr01
                    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                    04-23-2025, 01:48 AM
                  • Kaar3l
                    Samsung QLED QE65Q7FNAT only standby light
                    by Kaar3l
                    TV: Samsung QLED QE65Q7FNAT
                    PSU: BN4400940A
                    MB: BN94-12832K
                    I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                    09-24-2024, 01:35 PM
                    09-06-2024, 11:40 PM
