Samsung UN40MU6290FXZA IC1604 dump Help
This topic has been answered.
  • juas
    • 5
    • usa
    Could you help me... I have a Samsung with the following problem, dead TV, I disconnect the main power supply and the leds light up. I know it is a problem in the firmware in the IC SPI Flash W25Q40CL (IC1604)
    TV model: UN40MU6290FXZA
    Version: FB02
    Main Board Sticker: BN94-12640X
    Could you help me to repair the dump please. Thank you.
    Same issue like this post: https://www.badcaps.net/forum/troubl...3f-ic1604-dump
    I tried fixed bin but doesnt work, different model
  • Answer selected by juas at 03-22-2024, 06:25 PM.
    lotas
    • Jan 2016
    • 4843
    • Russia
    Originally posted by juas
    No lucky,
    This was a native dump, if it is a native one, then everything should work, after writing my corrected dump, you set and wrote status register 0x88, 0x42, without writing them, will the firmware be damaged again.
    • lotas
      • Jan 2016
      • 4843
      • Russia
      Version: FB02
      Try.
      • juas
        • 5
        • usa
        Originally posted by lotas
        Try.
        No lucky,
        Do you have any database?
        Can you sent me everything, to test them all ?
        If none of them work, I’ll have to buy the board
        • lotas
          • Jan 2016
          • 4843
          • Russia
          No lucky,
          • juas
            • 5
            • usa
            im using RT809F to write the dump,
            i dont know what this mean: status register 0x88, 0x42
            can you explain this, thanks
            • lotas
              • Jan 2016
              • 4843
              • Russia
              After write dump do this.
              And also, is the dump you posted his native one or did you already write something on it (different dumps) without saving his native one?​
              • juas
                • 5
                • usa
                Great, works, but I realize that the LCD is cracked, 😭.
                I have a question​: this dump its for any samsung board? or its a specified for this model, size,board shape,year,version?
                Thanks for all help.
                • lotas
                  • Jan 2016
                  • 4843
                  • Russia
                  Here the diagonal size does not affect the model either, the main thing here is that the series should be “MU” and that the software versions be the same for 25Q40 and eMMC.
                  • tvdarek1
                    Dump ic1604 Samsung UE50MU6102K
                    by tvdarek1
                    Tv Samsung UE50MU6102K
                    mainboard: BN94-12432B
                    matrix: CY-GK050HGNVHH
                    I lookin for dump IC604 W25Q40...
                    10-15-2025, 03:12 AM
                    09-07-2024, 05:50 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • jeangonbay
                    Samsung UE43MU6105K IC1604 dump needed - TV don't start
                    by jeangonbay
                    Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
                    The model of my TV is UE43MU6105K
                    Main Board: BN41-02568B
                    BN94-12007Y
                    02-16-2024, 05:46 AM
