SAMSUNG UE58MU6122 dump file needed
This topic has been answered.
  • unimatrix93
    • Oct 2021
    • 347
    • Magyarország
    Dear Community,
    I have a Samsung UE58MU6122 with no power LED.
    I checked the PSU, all output voltages are present so it's probably good.
    Doing some research I found that the corruption of the SPI memory chip can cause this problem and the TV started acting like this after a power outage.
    Can somebody please provide a dump file so I can flash it to the IC?
    Thank you!😊
  • Answer selected by unimatrix93 at 03-04-2024, 04:05 AM.
    lotas
    • Jan 2016
    • 4649
    • Russia
    Like this.
    In the program:
    1. Click "Detect Chip" and select W25Q40CL and "Select IC".
    2. Click "Unprotect".
    3. Click "Clear IC" and "Yes".
    4. Click "Open File" and select your corrected dump.
    5. Press "Program IC" and "Yes".
    6. Click "Verify IC".
    7. Press the down arrow to the right of "Unprotect" and select "SREG Edit", put a check mark on SRP0, BP1, CMP, QE and press "Write" and "Yes"
    7. Close the program. Ready.
    • lotas
      • Jan 2016
      • 4649
      • Russia
      Someone else's dump will not help, since the software versions are different, post your dump here, I will fix it.
      • unimatrix93
        • Oct 2021
        • 347
        • Magyarország
        Awesome, I extract the dump file and post it as soon as possible!
        Thank you!
        • unimatrix93
          • Oct 2021
          • 347
          • Magyarország
          Here is the dump file of the IC1603.
          https://1drv.ms/u/s!Ar4hHP2toEdohNZF...PlHJg?e=3co7kD
          and
          IC IC1604
          https://1drv.ms/u/s!Ar4hHP2toEdohNZG...yPd9A?e=TDnb4X
          Thank you again man, I owe you a pizza.
          • lotas
            • Jan 2016
            • 4649
            • Russia
            and
            IC IC1604
            I don’t need IC1603, it’s mainly IC1604 that suffers, I fixed it for you, try it, don’t forget to set and write status register (0x88, 0x42) after recording my dump!
            • unimatrix93
              • Oct 2021
              • 347
              • Magyarország
              I don't need IC1603, it's mainly IC1604 that suffers, I fixed it for you, try it, don't forget to set and write status register (0x88, 0x42) after recording my dump!
              Thank you very much, I fire up my programmer right up!
              Am I doing it right?
              • lotas
                • Jan 2016
                • 4649
                • Russia
                Like this.
                In the program:
                • unimatrix93
                  • Oct 2021
                  • 347
                  • Magyarország
                  Like this.
                  In the program:
                  Thank you for the detailed steps.
                  The TV turns on now as soon as I plug in the power cord, but it doesn't display anything. Black light on but black screen.
                  • lotas
                    • Jan 2016
                    • 4649
                    • Russia
                    It should not be. Have you tried to record something in ic1604 before (were there any experiments with it)? How did you record the dump through a clothespin or solder the chip through an adapter on the programmer? This happens if the dump software does not match the emmc software (that is, they have different software versions). Did you do anything with ic1603 or left it as is?
                    • unimatrix93
                      • Oct 2021
                      • 347
                      • Magyarország
                      I only saved (extract) the content of the two ICs I did not experiment with other bin files other than yours. I always desolder the IC, then solder it to a adapter which connects to the CH341A.
                      • lotas
                        • Jan 2016
                        • 4649
                        • Russia
                        Read this dump from 25q40 again and post it here again, I’ll see what’s written there. During dismantling and installation, nearby SMD resistors were not damaged or moved out of their seats.
                        • unimatrix93
                          • Oct 2021
                          • 347
                          • Magyarország
                          I uploaded the bin file. I also checked the SMD components around the IC they all seems to be fine. Thank you Sir
                          • lotas
                            • Jan 2016
                            • 4649
                            • Russia
                            Yes, everything is fine, strange, try a clean dump for your software.
                            • unimatrix93
                              • Oct 2021
                              • 347
                              • Magyarország
                              Okay thank you, Do I need to do the SREG thingy too on this one or just flash it?
                              • lotas
                                • Jan 2016
                                • 4649
                                • Russia
                                Yes, it's still the same. And maybe try to write to a new flash.
                                • unimatrix93
                                  • Oct 2021
                                  • 347
                                  • Magyarország
                                  Success!!
                                  I erased the IC and reflashed it with your fixed bin file in neoprogrammer (instead of asprogrammer) and it worked!
                                  Thank you again! You are the best!
                                  • lotas
                                    • Jan 2016
                                    • 4649
                                    • Russia
                                    Click image for larger version  Name:	IMG_20240301_154825.jpg Views:	0 Size:	4.62 MB ID:	3228255
                                    Success!!
                                    Ok! Thank you.
                                    • Citymin
                                      by Citymin
                                      S/N : 5RNK9FFT70...
                                      08-05-2025, 05:12 AM
                                      09-07-2024, 05:50 AM
                                    • GeckoGreen
                                      Samsung service bulletin: need firmware file for PN63C550 TV
                                      by GeckoGreen
                                      I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
                                      You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
                                      The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
                                      Will you please help me get the [2D63]LOGIC.bin file for my TV?
                                      05-17-2025, 02:47 PM
                                    • Forest79
                                      by Forest79
                                      However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                      07-23-2023, 07:39 AM
                                    • jeangonbay
                                      Samsung UE43MU6105K IC1604 dump needed - TV don't start
                                      by jeangonbay
                                      Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
                                      The model of my TV is UE43MU6105K
                                      Main Board: BN41-02568B
                                      BN94-12007Y
                                      Could you help me to repair the dump please. Thank you.
                                      02-16-2024, 05:46 AM
