Samsung UN50KU6300F constant reboot, bad backlights?
Shit, my bad, that one is for surface mount, let me grab the thru hole one, here: https://www.digikey.com/en/resources...tor-color-codeLast edited by nomoresonys; 02-20-2024, 06:45 PM. -
Here's one resistor chart, pretty easy to use, check some other resistors to see if you get a correct reading, wondering if your meter battery is ok: https://kiloohm.info/smd4-resistor/1004Leave a comment:
I assume that was in circuit, if so unsolder it and test it again, seems bad.Leave a comment:
I tested the SK34 diode on the bottom and it appears to be bad. It checks .298 both directions with one meter and 4.8 both directions with my other meter.
I have a spare board with a similar size but it's an SK510C. Could I safely use this in place of the SK34?Leave a comment:
Well lets make sure on that resistor, is it visible on here, if not what are the colors on it?Leave a comment:
Can you narrow down the location of the buzz-tick, maybe with a straw to your ear or such, make sure ALL the solders are good on bottom of board.Leave a comment:
I will check that diode though. HOPEFULLY that is it.
​Leave a comment:
Go ahead and check that diode in circuit, if it gives unexpected reading then you might need to unsolder to see, not sure what you mean by 1.2 on the resistor, they should be close to the rating of the resistor, if unsure maybe de-solder it and check.Leave a comment:
Last night I checked out a few things. First I tried heating up that capacitor and powering on. No change. Then I checked that resistor. It's supposed to be 600Mohms, and my meter being auto ranging showed it as 1.2. I'm not sure what that means, but it's showing resistance so I assume it's good. Last I checked that transistor. I was getting funny readings from it (different measurements between base/collector as base/emitter) so I replaced it. Also NO CHANGE. I still am getting power cycling and that buzz/tick sound in the video I shared earlier.
Whatever is bad literally prevents the whole board from powering up, and instead it just "reboots" over and over.
I forgot to check DM871 on the bottom of the board. I seen Hamie's thread about it being a common failure for this model power board. Despite being surface mounted, I still have to remove this diode to check it, correct?Last edited by x_orange90_x; 02-20-2024, 06:00 AM.Leave a comment:
I have a feeling it's that transistor. I will check that, the resistor, and that capacitor tonight. Id like to have kits of components on hand so I don't have to order so often. Like variety kits of transistors, diodes, resistors. Does anyone else keep stock like that, or just order what's needed when it's needed?Leave a comment:
Quick test, try heating C9371 with a hairdryer for a minute or two and retry it while it's still hot, no joy maybe test that resistor and test that transistor on the heatsink right there by it, see if any of the 3 pins are shorted to the other 2, or reads low ohms, should be able to test those in circuit. Try tracing where that bad diode goes, what components it leads to. And as always, make sure all your solder joints are good on bottom of board.Leave a comment:
Quick test, try heating C9371 with a hairdryer for a minute or two and retry it while it's still hot, no joy maybe test that resistor and test that transistor on the heatsink right there by it, see if any of the 3 pins are shorted to the other 2, or reads low ohms, should be able to test those in circuit. Try tracing where that bad diode goes, what components it leads to. And as always, make sure all your solder joints are good on bottom of board.Last edited by nomoresonys; 02-19-2024, 12:32 AM.Leave a comment:
I replaced it but I'm getting the same symptoms. I can hear a faint fast clicking like it's trying to come on. I've attached a video of the sound.Attached FilesLeave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by max789Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
I made the following tests:
1. Disconnected the main board from Power Board = backlight works.
2. Connected the main board and disconnected the T-Con = backlights does not work.
So I ordered a main board from Ebay also BN41-02156A but from... -
by brkieI have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
I read on Samsung's website (reviews)... -
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
