samsung LE40M87BDX/XEH big problem
  • olddog
    • Jan 2014
    • 8
    • greece
    hello
    i have a Samsung LE40M87BDX/XEH and recently appears some problems with the picture,the problem is that the faces an especially noses, forehead ,cheeks its very white and shiny or turned to pink, i forced to adjust brightness and color very low and it was little better ,but became very dark. anyway that was the small problem because yesterday i try to "play" with the adjustments in service menu for a try to fix it,but i don't remember what i change,of course i thought if you push the factory reset even if you do wrong will be ok,but i thought WRONG, now i have totally distorted picture like moving oil and after 5 resets nothing happened,did someone have the full settings of service menu?or some other solution? thanks be forehead and sorry about my bad English greetings from bankrupted Greece )
  • Dang
    • Aug 2013
    • 440
    Re: samsung LE40M87BDX/XEH big problem
    Take a picture of the settings you adjusted, the whole screen and also a picture of the sticker to the right side of the Tv, it might have SQ02 or AU07 or the like written on it.
    By the way, sounds like a possible T-con card problem, just need those photos and numbers to confirm.
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      sounds like a gamma chip problem,need pics really,do any of the chips get hot on the t-con?
      seem to be loads on here coming up with that problem,more of an epidemic!
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • olddog
        • Jan 2014
        • 8
        • greece
        hello again
        the label at the side of tv : LE40M87BDX/XEH
        SERIAL : AJOW36NQ
        VERSION : AC08
        the photos you asked :
        dtv : http://imgur.com/sWX6XKp
        http://imgur.com/SO5zShZ
        d-menu of dtv : http://imgur.com/QA7OoXH
        analogue tv: http://imgur.com/1BSdaPd
        and finaly the ( damned) :p service menu : http://imgur.com/TLaJS1a
        you know,if that happens suddenly i was thought ok,is broken,the time to pay has come,but it happened the exac time i restarted after i 'play' (stupid me) with the service menu.
        another stupidity of me is that i never notice down what parameters i changed because i was sure with the reset option grrrrrr.
        anyway the milk is on the floor no need to cry anymore,so i will follow your instruction
        thanks again
        • multimeter
          • Jan 2011
          • 739
          • united kingdom
          one false move in a service menu,and yer toast!
          • olddog
            • Jan 2014
            • 8
            • greece
            yes, i understand that now,maybe the damage come the same time you change something,and the reset option is useless after that.
            so can i do anything,or its time for a 3D at last? :p
            • Dang
              • Aug 2013
              • 440
              OK, within the service menu, go to "Option Table" and take a good picture of all the settings in there. AC08 suggests an AU Optronics screen, thus using the infamous AS15-F chip on the T-con and that's most likely your problem from the start. If it were slight in the beginning as you said, then we should be able to make it better, not perfect but better, it has to be said though either the chip or T-con card will need changing at some point.
              • olddog
                • Jan 2014
                • 8
                • greece
                i am very glad to here about even "maybe better" i hope so, here the photos of "option table" and of some other sub menus,sorry about the label "no signal' i could not do anything about it,but i can write here whatever you ask.
                option table: http://imgur.com/4JSXUKu
                other sub menus:
                http://imgur.com/u6wrEV0
                http://imgur.com/HCIfeHI
                http://imgur.com/w1HPmeD
                http://imgur.com/z9q3NHj
                http://imgur.com/vo5UnCM
                http://imgur.com/MsIZ7ak (this is really messed up because i forced to do it with contrast etc to take photos)
                there is more sub-sub menus if you need something tell me.
                as you said before in deed the problem before i put my hand in service menu it was small maybe the t-con just started to failure,but i wanded the perfect picture stupid stupid stupid
                • Dang
                  • Aug 2013
                  • 440
                  OK, not too sure what you've adjusted but the ones I'm interested in are:
                  INCH OPTION
                  PANEL VENDOR
                  PANEL TYPE
                  MODEL OPTION
                  Adjust PANEL TYPE remembering it's starting value and see what happens, this can make the colours go crazy just like yours if not set to the correct value.
                  Also try PANEL VENDOR, yet again remembering it's starting value.
                  The other two may have an effect too just remember it's starting value if you have to go back.
                  If any of these bring it back to where you saw it in the beginning then move to SUB BRIGHT, I found that by raising this value it removed the distortion you spoke of, the only trade off was a picture just a little washed out looking, basically too much brightness but the colours and distortion had been corrected. If you find this works it's a good idea to go back and forth to the normal menu from the service menu and try and adjust out some of the brightness, turning off DIne helped, as did turning black adjust to low or off, adjusting the brightness also helped but it's a balancing act, they all had an effect so just keep going back and forth till you get it as good as you can bare.
                  Basically, less picture processing turned on, the less brightness needed.
                  Just a word of warning, DON'T touch anything else in the service menu, there are some others I know of but a lot I don't, those other pictures you've shown, I have no idea what they are and wouldn't touch them because of, I hope this helps and good luck.
                  This is only temporary, the chip is on it's way out so will have to be changed in one form or another, I got about 4 months before it finally said night night.
                  • olddog
                    • Jan 2014
                    • 8
                    • greece
                    @Dang TY TY TY
                    After a few tries with panel type and panel vendor finally the problem Solved YES!!!!
                    of course the initial problem with shiny faces is still there but i don't care anymore maybe someday it need to fix the t-con,but for now the tv working just fine
                    http://imgur.com/BsRAubw
                    and imagine that: i almost totally broke my TV just for that :
                    http://imgur.com/GNG5N6S
                    thank u my friend i am grateful,keep going help the world
                    p.s and some advice from me (the stupid one) to all amateur users: don't mess with service menu
                    • Dang
                      • Aug 2013
                      • 440
                      Originally posted by olddog
                      @Dang TY TY TY
                      Glad to hear it. Did you try raising SUB BRIGHT or turning any of the picture enhancements off, did they make any difference on the shimmering?
                      • olddog
                        • Jan 2014
                        • 8
                        • greece
                        No, i goes directly in customer menu and with a little "playing" with contrast and brightness-color achieved to vanish shimmering,but i will try with your method tomorrow,of course with those adjustments the quality of picture is downgraded a little bit as you can see in the photos but is ok, when i have time i will try for the better result i can do,.and of course i will try your suggestion
                        i wanderer after that, you still insist about failure of t-con or you believe is something else?maybe something special in service menu adjustments?
                        with a very little decrease of contrast color etc:
                        http://imgur.com/x5fuVCU
                        after much more intervention: downgraded quality,like washed pale,but at list no problems
                        http://imgur.com/ECUFw5t
                          09-07-2024, 05:50 AM
                        • howardc64
                          Samsung UN55JU650DF network/streaming problem
                          by howardc64
                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                          07-09-2025, 12:44 PM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
