oynx sw3210lcd no respond red led on steady
  • mick67
    • Dec 2013
    • 9
    • United Kingdom
    Need some help guys hope you can help
    Have got onyx sw321olcd that was give to me.its stuck in standby.
    the power supply was faulty as the 12v rail was giving out 18v on com 4.
    replaced it.its working ok now.
    now the stp smps on/off control is staying on high on pin 5 of con 5.
    also pin 6 5vsb standby is high at 5.08v
    changed the main av pcb same thing is happing
    hope you can help
    the supply voltages on the MLT666B power supply are
    con4 pin 3 =5 pin 5=4.6 pin 6=5.08 pin 8=5
    con5 pins 1-4 =25v
    Thanks Michael
  • mick67
    • Dec 2013
    • 9
    • United Kingdom
    Re: oynx sw3210lcd no respond red led on steady
    Looks like my post not getting many views is this because the tv is an odd ball thing lol
    • av4x
      Fujitsu U7511 liquid damage, wont turn on anymore, does not respond to charger in any way.
      by av4x
      Good morning, everyone!
      I've gotten my hands on a few laptops with various defects because I want to get more involved in repairing electronics.
      First up is a Fujitsu Lifebook U7511.
      It won't turn on anymore and doesn't respond in any way when you plug in a power adapter.
      Model: Fujitsu Lifebook U7511
      CPU: Intel Core i5-1135G7
      GPU: Intel Iris Xe Graphics
      RAM: 16GB DDR4 - 3,200 MHz
      PCB manufacturer: ASKPCB?
      PCB serial numbers: CP801602, CP7984241-Z4, E239218, CP809978-01
      Damage: Liquid damage
      The liquid probably...
      11-01-2025, 03:09 AM
    • tbsmith
      Ninja DCT401 Double oven/air fryer Possible microprocessor issue?
      by tbsmith
      I'm having a random issue with this otherwise nice double oven/air fryer. It sometimes does not respond to the controls. Sometimes only the upper control buttons work, sometimes they all work and sometimes none of them work. The power supply is good as the control board has a steady 5V and 3.3V. The pushbutton switches are all good as tested with multimeter. When the buttons are working, there is about 2.5V to the high side of the pushbutton. I'm assuming pressing a button grounds the input pin to the microprocessor. When the buttons are not working, there is about 0.3 volts on the high side....
      07-12-2025, 11:40 AM
    • Noah Glasse
      LG 50PK590 - three clicks and steady red light, won't turn on.
      by Noah Glasse
      I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
      I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
      02-24-2025, 07:23 AM
    • koby058
      Dell optiplex 990 steady orange light
      by koby058
      Hi
      FOXCONN E253117 94V-0 ML1-Y MOTHER BOARD
      when connecting power its fan starting no beeps and steady orange light
      No post and nothing on screen
      Any body have idea about test direction ?
      12-10-2022, 11:36 AM
    • madfreak
      DELL Inspiron 7570 - keys do not respond when fast typing / lagging ( even in BIOS \)
      by madfreak
      Laptop from the series: "I was charmed by your story"... The laptop after flooding and everything works 100% correctly except the keyboard.
      Description of the fault: When typing very quickly, the keys "lag" / showing with a delay, if we press them individually and slowly, each button works normally and the characters are entered... and now to make it more funny, when we press any button and we hold it down, a given character appears on the screen very quickly.
      History of the laptop and description of the activities performed:: Laptop after flooding,...
      06-20-2024, 09:52 AM
