Panasonic TH-58PX600U 7 blinks
  • havanajack
    • Dec 2013
    Hello, I'm very new to this forum and have joined in order to obtain any type of assistance or wisdom regarding my non-working Panasonic TH-58PX600U Plasma television that was manufactured in Sept of 2006.
    I have searched and read a number of the threads regarding the Panasonic 7 blinks of death but none have directly answered some of my concerns...likely because of my electronic ignorance. I am a DIY type of guy but may be jumping into waters too deep for me.
    Is there an easy way for me to test which board is faulty? I have yet to pull off the back panel. And even if I'm able to determine the faulty board, how much would it cost to replace it? Can I purchase a refurbished board? With 50 inch tv's as inexpensive as they are, would wisdom dictate just buying a new one or would it be worth the effort to fix my current television. I remember paying 4k for it in late 2006. Crazy, i know.
    I am leaning toward at least determining the current cause of death and seeing if I can attempt to fix it for under $150. If not, is it worth selling the tv as is and letting another repair and resell it.
  • Andre Gilbert
    by Andre Gilbert
    11-20-2024, 08:52 PM
  • Biruslapio
    Panasonic P58V11B 8 and 12 blinks error "fix"
    by Biruslapio
    Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
    Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
    04-13-2021, 07:13 AM
  • jm1234
    Panasonic plasma TX-P42ST50 - 6 blinks
    by jm1234
    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
    I checked that board for any obvious faults...
    05-22-2024, 06:59 AM
  • Alicat
    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
    by Alicat
    Stopped by this site trying to fix my parents Panasonic Plasma TV.
    Model number is TH-50PZ85U
    Power comes on and the red power light stays on solid.
    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
    I also hear a few clicks.
    I also think my parents said there was a thunderstorm and the TV failed after that.
    Section 6 in the service manual talks about power and no screen,...
    10-30-2024, 10:09 AM
  • renech
    panasonic TH-42PC77U plasma television half screen problem
    by renech
    hello,
    I hope someone on this forum can assist me.
    I have a panasonic TH-42PC77U plasma television.
    the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
    i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
    I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
    I have read some posts that suggest the problem is related to the boards on the left...
    12-12-2022, 06:53 PM
