Samsung SP-R4232
  • dnafix
    • Oct 2012
    • 8
    Samsung SP-R4232
    I got this plasma to work on and it has a very bad pic. I have worked on many but this one had corrosion on the main board and it looks like the lower Y board as well bad. The vertical red lines I think are from the main board corrosion and the other lines are due to the y-lower.. Anyone have any other ideas?
    Here is a pic of the screen
    Here is a pic of the main, lower Y and Upper Y board.
    Here is a pic where the corrosion I cleaned was.
    The only voltage that seemed off was VE and it was 75 tag said it should be 110
    Re: Samsung SP-R4232
    I would say that both your Y-buffers are bad, pretty common symptom with these sets.
    • dnafix
      • Oct 2012
      • 8
      Thanks, I didn't think it could be both but your probably right.
        09-07-2024, 05:50 AM
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
      • JSin21
        Compatibility of main boards between different variations of samsung MU6100
        by JSin21
        Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
        I have Samsung Smart TV UA65MU6100WXXY version DA01
        Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
        11-27-2023, 04:54 AM
      • Yanleb
        Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
        by Yanleb
        Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
        If they are not compatible why did Samsung give them the same part number to begin with?
        08-04-2025, 11:35 PM
      • elpatxi_bcn
        Samsung HG75EJ690UB Hotel TV, change main?
        by elpatxi_bcn
        Hello!
        I just got a Samsung TV model HG75EJ690UB 75" and 4K. It is a hotel TV, with a slightly different version of the Tizen operating system than the TVs at home.
        Being a hotel, it is covered in many functions. With the service menu I can unlock some, but not others. For example, I can't install apps like Netflix etc...
        The fact is that it seems that I can replace the main by a, say, "normal". I think the one that corresponds is NU7105, ref BN94-02635. At work, which is a convention center and a hotel, I have many TVs from 55" to 85" that...
        05-19-2023, 03:21 AM
