Samsung PS42Q97HD
  • Longneck
    • Nov 2013
    • 8
    Samsung PS42Q97HD
    i have a 42" plasma tv sat here. the original fault was that there were red lines and dots on the screen. so i opened the back and saw that 16 caps needed replacing. so i obviously replaced all of the caps. i then tested the thing and it just came up with a blank screen. i turned off and on again and saw that the blue light flashed 5 times and then turned off. when i read up on this it said to change caps?? looked at the y main board and a few of the green 2A fuses needed replacing. so i did and i still get the 5 blinks and no picture. please help, thankyou
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Samsung PS42Q97HD
    What caps did you use?
    • Longneck
      • Nov 2013
      • 8
      same values, they weren't cross tops, can't remember the make of them. just need to know which board it would be
      • newtothis
        • Mar 2013
        • 1556
        • england
        As long as they were low ESR they should work.
        Disconnect a board at a time from the PSU and switch the set on... check the standby led for the 5 blinks.... if still there turn the set off and reconnect the board... disconnect the next one and do the same until you dont have the 5 flashes.... that disconnected board will be your problem
        • Longneck
          • Nov 2013
          • 8
          i did as you said. i unplugged the y main. it still had the 5 blinks, and the same when i unplugged the x main. then i unplugged what i believe to be the logic board. this didn't even power on the tv. so lastly i tried unplugging the control board and the tv turned on did the 5 blinks and then turned itself off. it then proceeded to turn itself back on and do the 5 blinks again. it kept doing this in like an infinite loop
          • Longneck
            • Nov 2013
            • 8
              If you used generic caps, you could have caused more problems than you originally had. Do not use generic caps. Panasonic FM/FR/FC are advised, generic Maplin special are not.
              I have only ever seen bad caps on the Y-main of these sets. Never PSU.
              5 blinks of LED is normal power up procedure.
              So check all soldering etc.
              Red sparklies are usually caused by misadjusted Yrr/Yfr.
              • Longneck
                • Nov 2013
                • 8
                hmmm well these caps were blown all over on all three boards. looks like i'll just have to ber it. thanks for the help
                • Longneck
                  • Nov 2013
                  • 8
                  http://postimg.org/image/alt7k2x4z/
                  that is the y main
                  http://postimg.org/image/fpdyebdmj/
                  the x main
                  http://postimg.org/image/uoqyi9y9h/
                  the psu
                  http://postimg.org/image/3ve3etwgj/
                  and what i believe to be the logic main. as you can see none of the caps are blown. hope this helps
                    09-07-2024, 05:50 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
                    Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                    This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 06:20 PM
