Toshiba LCD 22BL502B Solid Green Led No Picture
  • tanz0
    • Nov 2013
    • 31
    Re: Toshiba LCD 22BL502B Solid Green Led No Picture
    You'll have to forgive me I've seen this term 'T-con' used a lot but not entirely sure what this is. Is this the LED driver board, in which case yes this is the board the inductors are on.
    The inductors are reading 3k and then quickly dropping to 0. Both of them have same behaviour though so it's unlikely this is problem. They do look somewhat burnt though. Any way of verifying exactly what problem is. Where would be a valid test point on driver board to check the current is getting past this point in circuit.
    I have tested the current across the fuse and multimeter indicates connection is good. Are there any other common faults with this board ?
    Having tested outputs on PL706 are correct, can we rule out mainboard/firmware problem ?
    Michael.
      100 is possibly 10uH too, if it is 10x(10^0).
      • tanz0
        • Nov 2013
        • 31
        Hello, just wondering how, if at all, can the led driver board be replaced, the various ribbon cables seem to be attached to both board and screen. Although I do see led driver modules on eBay.
        Michael.
        • tanz0
          • Nov 2013
          • 31
          I read somewhere here that it is possible for a T-CON fuse to be defective, but still pass current, just during operation the resistance increases until the board fails to operate, instantaneously of course. Is this true ? Also hear some discussion around using 'ice spray' to diagnose bad components ?
            The t-con is the board currently being worked on; no it can't be replaced due to it being bonded to the LCD panel.
            Your suggestion of intermittent fuse is possible; to test it you could measure the voltage on both ends of the fuse, if it is 12V and both ends the fuse cannot be causing the fault.
            • tanz0
              • Nov 2013
              • 31
              Thanks. Jumping back to the inductor problem speculation previously discussed, it's noticeable that the T-con protective cover has a small window cut out for just these two inductors. Precisely the correct size for inspection and or heat dissipation. I'm wondering then are these components prone to fault. I've seen others speculating about faulty inductors here but there seems to be a consensus they are rarely the culprit.
              I intend to borrow a meter and measure inductance directly.
              Thanks.
              • tanz0
                • Nov 2013
                • 31
                One more thing. Finding it difficult to test these parts since they need to be grounded on the chassis to operate correctly. However the chassis prevents access to the t-con board and the cables aren't quite long enough to reach when chassis is moved elsewhere. Do the boards generally have a ground line soldered to them each, both power supply and mainboard, when being tested.
                  The inductors are probably not causing the fault. Failure rates of inductors are very low, they consist of coiled wire and a magnetic coil. The main failure mode is for them to fail open circuit but AFAIK you tested that did you not?
                  • tanz0
                    • Nov 2013
                    • 31
                    I did yeh, I was speculating though the wire could have fused at some point along the coil, which would fail closed circuit, but would alter inductance. In any case it's prob unlikely this would cause total blackout.
                    I'll need to test the fuse when it's in operation.
                    Cheers.
                    • tanz0
                      • Nov 2013
                      • 31
                      Hello, I have tested fuse, there is a steady 12.45v across both ends so I don't think this is the problem.
                      Can anyone tell me what the correct voltages should be for backlight connection. I have com, and ch1-4 marked on board.
                      12.45v between com and chassis, 3.3v on ch1-4.
                      Does this look like a backlight problem ? I can see absolutely no picture when it is on during day in bright sunlight.
                      Thanks.
                        For a 22", much higher, around 30V for one pin, low voltage on each return pin. Good news is there doesn't look to be any shorts on the LED strip, that can be ruled out for now then, so it is somewhere on the t-con.
                        Looks like the boost converter taking the 12V is not working. There is a chip next to the LED connector, what is the part # on this?
                        • tanz0
                          • Nov 2013
                          • 31
                          Hi, which chip do you mean ? There are 3 in the vicinity.
                          One square to the left, looks around 40 pins or so. One rectangular above, 8 pin. And one rectangular to the right, around 20 pin.
                          Square one looks like OISWL-0058A. I could be a one of course.
                          8 pin looks like st 404rp ?
                          Thanks.
                            I mean the one closest to the connector going to the LEDs. The one you measured 12V, 3.3V, etc on.
                            • tanz0
                              • Nov 2013
                              • 31
                              Hi looks like b0926-1efv. Also has 130-ht4 on it.
                              Thanks.
                              • tanz0
                                • Nov 2013
                                • 31
                                I see 4 small components adjacent to the chip. Do these boost converters use external caps for charge pumps ? Will try an find out, those model numbers return no results. Even trying to see the model numbers with a magnifying glass is difficult. And I have 20/20 vision, apparently.
                                Thanks. In the event of this chip itself gone, I take it that it is game over, how could you swap this component out, hot air soldering iron ? Caps look potentially feasible.
                                • tanz0
                                  • Nov 2013
                                  • 31
                                  Think that's bd926-1efv
                                  Rohm led driver apparently. What are the common problems that develop with boost controller ? Caps burn out ? You could do a hot air rework of the chip ?
                                  Thanks.
                                    The topology is an inductive boost converter,
                                    It seems that IC fails often from a little googling, but no-one has a datasheet. You can replace it with some skill, or you could probably use an external LED driver.
                                    • tanz0
                                      • Nov 2013
                                      • 31
                                      Ah, cheers thanks. Just to reiterate though, I see no picture on screen at all in bright light, you're convinced that this is the only problem with the t-con board ?
                                      Thanks.
                                      • tanz0
                                        • Nov 2013
                                        • 31
                                        Having great difficulty trying to get a datasheet for this screen.
                                        I have managed to find an external led driver that looks suitable to drive backlight off existing 12.45v, however it has 4 connections, including DIMMER control and standby.
                                        The backlight connection on the LC216EXN has 6 pins, I'm wondering do you know what these are for. As previously mentioned, they at labelled COM , CH1-4 and I assume GND.
                                        • tanz0
                                          • Nov 2013
                                          • 31
                                          Link to driver btw:
                                          http://uk.farnell.com/midas/ledv1/le...all/dp/2219006
                                          • DarrenHD
                                            Firmware for older Toshiba TV 22CV100U
                                            by DarrenHD
                                            HI all, Does anyone know if there exists an archive for older firmwares for Toshiba TV's? I've searched all over Toshiba's various websites and also on Dynabook's site (they say they deleted all old firmwares due to "server space". ) Toshiba has not replied to my request.
                                            I'm looking for Firmware 1.07 for the 19/22/26/32 C100U series as described in this link:
                                            https://support.dynabook.com/support...tentId=2865076
                                            Thanks!
                                            06-16-2025, 11:56 AM
                                            09-06-2024, 05:27 AM
                                          • lberkani
                                            Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
                                            by lberkani
                                            I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
                                            The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
                                            The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
                                            I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
                                            - Toshiba 65UL2163DG
                                            - Vestel 17MB180E mainboard
                                            - Panel VES650QNTX-N2-N42
                                            - Version V1.28.100.0 if available
                                            If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
                                            11-11-2025, 12:37 PM
                                            09-06-2024, 05:59 AM
