JVC LT-22DE72 only 1/3 of display shows up
  • mguzinski
    • Dec 2012
    • 19
    Hi All,
    I'm fairly new here but since joining the forum I have fixed about 6 LCDs with new capacitors diodes and resistors. Once I did have to get a new board however.
    This time I got a JVC LT-22DE72 that only displays the upper 1/3 of the screen. I have had this problem with laptop displays in the past and commonly it was a cable that needed replaced or reseated.
    The display fully lights up when the video board to inverter board cable is unplugged. Sound and the image at the top 1/3 of the screed looks good. No obviously bad capacitors or any other burn marks on any of the boards. The display acts the same with any input source.
    I have not measured any components as of yet but I have reseated all the cables and messed with the ribbon cables to see if the display changed at all. I have also tested continuity on the cable going from the video board to the inverter board and that tested fine.
    Any other tips on testing this one? I'm a little lost right now.
    Thanks in advance for your assistance.
    Mike
    [/URL][/IMG]
    [/URL][/IMG]
    Re: JVC LT-22DE72 only 1/3 of display shows up
    Can't see the pictures you have linked?
    • mguzinski
      • Dec 2012
      • 19
      Lets try the links...Can't seem to get them to use Google Drive to display them as IMG
      • aaronwt6
        • Apr 2013
        • 855
        • US
        I'm going to vote T-con board but I've never seen one do this. Strictly a guess.
          I'm going to say panel personally.
          • aaronwt6
            • Apr 2013
            • 855
            • US
            Was thinking the panel issues were usually oriented vertically. Not the case I guess? Just asking for future reference.
            Still learning.
            • mguzinski
              • Dec 2012
              • 19
              Now...not sure this is relevant but when I disconnect the cable from the main A/V board the display shows completely lighted up. Would that still be the panel? I thought if it was the panel only the upper 1/3 would show lighted like it is when it has an input.
              Thanks again...
                Still learning.
                Panel issues can occur in both axes.
                • aaronwt6
                  • Apr 2013
                  • 855
                  • US
                  Ah ok. I gotcha. Just hadn't seen one that looked like that.
                  • aaronwt6
                    • Apr 2013
                    • 855
                    • US
                    Thanks again...
                    All that means is that the backlight is working.
                    • mguzinski
                      • Dec 2012
                      • 19
                      Is the t-con board the same as the main A/V board on this set. The ones I have seen before have a separate t-con board.
                      [/URL][/IMG]
                      • aaronwt6
                        • Apr 2013
                        • 855
                        • US
                        Looks like its all in one on this set then. I'd go with Tom's instinct over mine. He's been around a heck of a lot longer. Wouldn't put any money in to a guess on something that size.
                        • mguzinski
                          • Dec 2012
                          • 19
                          That sounds like a bummer...Some times you win some times you don't. Guess I can part it out. Seems like the LCDs are in the $120 range.
                          Thanks all for your advice and insight!
