samsung plasma need help please !!!!
  • squirel
    • Oct 2013
    • 18
    • england
    please help my samsung plasma ps50 has developed a problem that effects only the left side of the screen lots of fuzzing and lines which change according to the picture displayed and is on all inputs
    Re: samsung plasma need help please !!!!
    When you get the set open, take some good, clear photos of the boards inside.
    • squirel
      • Oct 2013
      • 18
      • england
      had the back off today and gave it a good blast on the connectors but no change have taken pics of the boards to the left and right
        Looks like an E5xx-series Samsung? That is only 2012 TV! Wow. Early failure...
        I need a look at the board to the left of this photo, where the white cable comes off the main board.
        https://www.badcaps.net/forum/attach...7&d=1382450102
        • squirel
          • Oct 2013
          • 18
          • england
          i know just a month or two outside of warranty is this the board
            Yes, on the left. Need a closer picture of that.
            • squirel
              • Oct 2013
              • 18
              • england
              hope these are ok. The stuff on the black square in the center is where my cat has sprayed the rear of the tv wait till i see him next
                Cat pee can cause a lot of problems for electronics, is that before the problem occurred or just now?
                Do you see those four copper plated holes top left corner of this image?
                https://www.badcaps.net/forum/attach...9&d=1382462412
                You need to take a piece of wire or a crocodile clip and connect the holes marked 3 and 4, then unplug the bottom most connector (on the same image.) Plug TV in and you should see test patterns, are they still distorted? (Note, make the connection changes while TV is unplugged then plug TV in to test.)
                • squirel
                  • Oct 2013
                  • 18
                  • england
                  just to be sure is that the one with the blue tab on it ? or the lowest white one
                    Blue tab yes.
                    • squirel
                      • Oct 2013
                      • 18
                      • england
                      yes distorted on all colours cant see it on the first screen which is plain white
                        OK, this indicates a control board problem or bad C buffer board.
                        Unplug the power to the set.
                        Reseat (unplug and re-insert) the left two white connectors. Same image as before
                        Trace them to the other end -- the C board. Reseat them there too.
                        Same issue?
                        • squirel
                          • Oct 2013
                          • 18
                          • england
                          yes still the same
                            OK, can you post one large picture of the whole chassis? I have one last theory that it could be a loose Va (C-buffer power) connector. If not you will have to replace the C buffer board (this is NOT the same as the Y buffer board...)
                            • squirel
                              • Oct 2013
                              • 18
                              • england
                              thanks for this
                                Looks like the power comes in to the right hand C board and goes to the other board. Had hoped this was like 2011 panel where it came in from the left. Anyway I think the only solution is to replace the right hand C board. This is also sometimes called the F buffer board. Shouldn't be too expensive to replace.
                                If you cat did pee on the control board, I would also suggest you replace that just in case.
                                What is the full model number of your set for example PS51F480.
                                • squirel
                                  • Oct 2013
                                  • 18
                                  • england
                                  ps51e490b1k
                                    I just checked. The E & F buffer boards on your TV are bonded to the screen! They cannot be replaced. The only hope is maybe a control board would fix it... but if not, then the TV would have to have the E/F board directly repaired (at the component level) which may or may not be possible.
                                    http://www.ebay.co.uk/itm/LVDS-BOARD...item3386101e58
                                    What a stupid design!
                                    • squirel
                                      • Oct 2013
                                      • 18
                                      • england
                                      ok well a huge thankyou for your help and time will give it a go at that price and report back with any developments thanks once again
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        And yet another fine example of non replaceable simplicity. Considering the amount of cat pee in the control board I would clean it thoroughly with electronics cleaner spray and a brush and check the right side ribbon cable connections where it goes to the control board from the panel for corrosion. Also the pins inside the connectors on the control board for corrosion as well. Cat pee is extremely corrosive
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
