Samsung HPS4253 Blue Snow/Sparkle
  • Mrpuding
    • Sep 2013
    • 14
    Samsung HPS4253 is having a Blue Sparkle problem I Think. When you first turn the TV on and there's no component currently on and it's the blue screen(no component Screen) there's static in the corners of the TV. When I Do turn the cable component on there's no noticeable static at al. After a while of use I start to get this blue sparkle (maybe blue snow) effect in In the corners of the TV. If I turn the TV off and turn it back on the Blue Sparkle is gone. It seems to only happen when the TV has heated up for awhile and has been used for awhile. The time period of use where this Blue Sparkle happens does vary. I've done some research and have heard that maybe this is a voltage problem. I was wondering if you could help me finding a solution
    Re: Samsung HPS4253 Blue Snow/Sparkle
    This is probably related to the Vs, Vset, Vscn voltages or the Yrr/Yfr timing adjustments. Pictures of the boards inside your TV would help. Do you own a digital multimeter?
    • Mrpuding
      • Sep 2013
      • 14
      Yes I do
        Can you take clear photos of the circuit boards inside your TV using a digital camera and upload them here?
        • Mrpuding
          • Sep 2013
          • 14
          I"ll Take Pictures of the My boards when I get back from work.....
          • Mrpuding
            • Sep 2013
            • 14
            Heres some pictures.....let me know what else you need
              OK, do you see where to test the various voltages on this sticker?
              https://www.badcaps.net/forum/attach...4&d=1380473793
              The voltages are found on various connectors on the power boards. The red probe goes on a test point, black probe on chassis, and meter set to 600V/1000V DC (if manual ranging) or volts DC if autoranging.
              • Mrpuding
                • Sep 2013
                • 14
                so I'm guessing if the voltages are off that's what would be causing the problem? then all I do is use the adjusters and adjusted to the right settings
                  It could be that. No guarantees. If it is though, then yes, usually a simple adjustment will fix it.
                  • Mrpuding
                    • Sep 2013
                    • 14
                    So Tom, You helped me out with this TV last year and would like to say that you were right. I was hoping that you could assist me again with my newest problem with this TV. I came back from a business trip to turn my TV on and found that there is a single thin blue line vertically going down the right hand side of the TV. From the little knowledge that I do have my gut is telling me that it is the Plasma Panel. I turned on the TV menu screen and the line goes over the menu screen. So I figured I would take it a step further and did a Signal pattern test and found that the single line is visible when the black goes over the line but hardly visible when the white part of the test goes over the line. I've heard that it could be the T-con board, But as I stated earlier my gut is telling me that the Plasma panel has finally started to show its age. I have attached a picture so that you can see what the line looks like. So if you could assist me I would be ever so grateful. Thanks Again.
                      09-07-2024, 05:50 AM
                    • Egidio85
                      Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                      by Egidio85
                      Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                      the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                      the fan does not start.
                      I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                      any advice on what to check?
                      06-10-2025, 05:00 AM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
