Question about Y sustain boards on a LG Plasma
  • lugh611
    • Sep 2013
    So I bought a 50 in LG Plasma from a guy and he said that it did not have a picture but has sound. He said that he had a tech look at it and that he needed a new Y sustain. So he bought it but said it was a little different and couldn't connect it. I get it home and tinker around with it and I notice that the boards are a bit different.
    Well the TV is an LG 50pc3d but the new board he bought was for 50pc5d. I am just wondering if this board should work with the TV, or if there is a work around to make it work, or if I will need to purchase a board for 50pc3d.
    Thanks in advance for any responses and help given, Just an FYI this is my first attempt at fixing a TV and I'm definitely a newbie at electronics.
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Question about Y sustain boards on a LG Plasma
    You will need the board for the 50PC3D. You can send your board out to Coppell TV repair (Google it) to be repaired for around $100. Or if you think you're capable of doing it yourself, you might be able to desolder the ICs from both boards and swap the ones from the "good" board onto the bad one. Post pics of both sides of both boards, someone here should be able to tell you if that's even possible. Are you sure the "good" board is actually good?
    With all that said, unless you got the thing for free, this TV is not really worth the money it will cost to get it working. Yes it's a 50" plasma, but even if you do get it working, it will likely have maldischarge, or what they call "sparklies" here on this site. That is fixable too, but will likely cost more money in the long run.
    • ugamazing
      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
      by ugamazing
      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
      12-17-2024, 07:05 PM
    • Erik Masters
      Panasonic plasma A boards/Kuro media box repair.
      by Erik Masters
      Hi all.
      I have 2 Panasonic plasma A boards for ST50 50"/65" and Kuro KRP 500A media box which needs repair.
      I'm not good enough at component repair so I need some help.
      A boards and especially Kuro media box is still very valuable and I can't throw it away like some average Joe,lol
      I'm from Europe/Slovakia and I'm searching for someone who is willing to repair these things or some tips at least.
      Both A boards have HDMI issue either no signal or flickering.
      And media box possibly with voltage regulator issue which is common...
      11-17-2022, 04:47 AM
    • ugamazing
      Apple M1 Boards & Exclamatory Error?
      by ugamazing
      We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
      Has anyone else run into this...
      02-20-2025, 09:24 AM
    • ugamazing
      Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
      by ugamazing
      I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
      08-31-2022, 07:34 AM
    • pixelcap
      Pioneer Plasma 111FD To Solder or Not to Solder.
      by pixelcap
      Hello out there in Badcap land.
      I have a Pioneer plasma that gave me the dreaded 8 red blink and shutdown, I have been trying to trace the failure points. On my last inspection while replacing a Y Sustain Board I noticed on the original and replacement board some missing solder, the points of connection
      are from the Digital Address Board and the Buffer Boards. I have included the pictures, should I resolder these points or are they unsoldered intentionally? Any help would be much appreciated.
      Thank you
      Pixelcap...
      03-08-2025, 07:10 PM
