Samsung PN43D490A1DXZA
  • preshongsan
    • Sep 2013
    I've browsed the forums and can't exactly find anyone who has had my problem. I'll explain. Wife was playing on our PS3, was done and switch sources and the TV shut off. I came home, unplugged it, waited an hour and plugged it back in. When I did just clicked 3 or 4 times. The red led light would blink a bunch, but the TV would not turn on by using the remote or the controls on the TV itself. I do not even believe it was in a stable standby mode. So I figured it was probably a power supply as this had happened to a friends tv. So I replaced the entire power supply. It however did not fix my issue. It remains the same. So I tried unplugging the Y main, plugged it in and I only got the one click this time, but the red led light does not stay illuminated just blinks. The tv will not turn on, no grey. Just black. The same result came after I tried unplugging the X main. Any suggestions? Honestly my next idea would've have been to replace the main board. However, I know very little about this so I'm leaving my self at the mercy of the gods as it were.
  • capkid
    • Oct 2010
    • 1339
    Re: Samsung PN43D490A1DXZA
    Try this: http://www.youtube.com/watch?v=JjrwTZC5nVg. Here's a related thread: https://www.badcaps.net/forum/showthread.php?t=31423. Post 14 might be of interest.
    LG Plasma Mal-Discharge Correction Service
    • besnikfe
      • Oct 2013
      I have the same problem. Even that the caps looked all ok, I replaced 3 caps and still the problem was there. 6-7 clicks, black screen and the red lid blinks.
      I replaced the power supply board. Still the same problem. I don't know what else may be the problem. How do we find out what the problem may be?
      Thanks.
        Most likely X-main board.
        Suggest you read this thread and try all indicated tests.
        https://www.badcaps.net/forum/showth...light=ps43d490
        Keep all replies in the current thread here.
          09-07-2024, 05:50 AM
        • Asraf Atb
          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
          by Asraf Atb
          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
          01-27-2025, 05:02 PM
        • JSin21
          Compatibility of main boards between different variations of samsung MU6100
          by JSin21
          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
          I have Samsung Smart TV UA65MU6100WXXY version DA01
          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
          11-27-2023, 04:54 AM
        • mrautom8
          Samsung TV UN75H6350AFXZC main board schematics?
          by mrautom8
          Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
          Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
          While relay is on, all voltage rails are present and steady (scoped) on main board.
          I love a good logic puzzle but getting lost without any schematics.
          No shorts on ANY capacitor main board.
          Thermal camera shows 3.3V inductor getting warm instantly but...
          10-19-2025, 06:32 PM
        • Yanleb
          Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
          by Yanleb
          Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
          If they are not compatible why did Samsung give them the same part number to begin with?
          08-04-2025, 11:35 PM
