samsung ps42q96hd
    Re: samsung ps42q96hd
    OK, closer pic of this highlighted section please.
    • pauluk00
      • Jul 2013
      • 29
      • united kingdom
      hi tom did you get my last picture
      • pauluk00
        • Jul 2013
        • 29
        • united kingdom
        here you go
          OK, see the fuse? Can you check the voltage you get on both ends please?
          • pauluk00
            • Jul 2013
            • 29
            • united kingdom
            hi tom , does the tv need to be on ,, and what do i set the multimeter at
              Yes, TV should be on, use the same multimeter settings as before to test Va.
              • pauluk00
                • Jul 2013
                • 29
                • united kingdom
                #27
                it reads 637
                  63.7V, both sides of fuse, red on each end, black on ground/chassis of TV?
                  Assuming you did the control board jumper correctly, the fault must therefore be on the control board.
                  Please show me how you set up the jumper & LVDS unplugged so I can confirm.
                  • pauluk00
                    • Jul 2013
                    • 29
                    • united kingdom
                    #29
                    yes it was 63.7v eash side ,i use a clip off the end of wire to attach to a speaker and placed it on the top 2 prongs,unpluged the cable that goes to the av board , then plugged the tv in ,then switched it on , came on with nothing on the screen ,,
                      Was the screen still glowing slightly after you did this?
                      If so, the control board is most likely the fault.
                      • pauluk00
                        • Jul 2013
                        • 29
                        • united kingdom
                        #31
                        yes screen was still glowing ,, does that mean a new control board?
                          Yep.
                          • pauluk00
                            • Jul 2013
                            • 29
                            • united kingdom
                            #33
                            thanks for your help tom ,, i,m very thankful for your time
                            • jollyranchers
                              • Jan 2014
                              #34
                              Hey guys I have exactly the same TV however the fault with mine is I have no VS voltage present which should be 205 VDC, I'm lost as to whether its a power supply fault or AV board fault
                              Is there a test I can do to narrow down the fault
                              any advice or help much appreciated
                              • Alastair E
                                Chief Womble
                                • Mar 2013
                                • 1963
                                • U.K.
                                #35
                                Need to start a New Thread--This is a different set with a different fault from the O/P.
                                BTW--Unplug the PSU to Y-Main thick cables and re-check Vs and Va at the PSU.
                                --These absent--prob duff PSU
                                IF they come up within a couple of seconds of switch-on then decay, could be something else causing a protection shut-down.
                                TELEFIX
                                  09-07-2024, 05:50 AM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
                                  Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                  This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-06-2024, 06:20 PM
