Ilo 32" HDTV buttons or remote control don't work
  • newtotvrepair
    • Jul 2013
    • 13
    Hi all:
    Yes, I know this TV is junk. (Ilo 32" HDTV from Walmart)
    None of the buttons, except on/off work on the TV (no volume control), nor on the remote control.
    I replaced the main board (DTV3218ATM V2.3 QAM), but that didn't do anything. (yes, I have no idea what the real part is that needs replacement.)
    The problem began when I plugged in the HDMI cable and something went dead/poof, leaving only the on/off button working.
    Any ideas on what the real problem is? Perhaps the T-con? Does the new board have a new TV remote code that I could put in my universal remote to solve the problem?
    Thanks in advance,
    N2TR
    Re: Ilo 32" HDTV buttons or remote control don't work
    Just to clarify, if you connect a source to whatever input the TV is stuck on you -do- see a picture?
    • newtotvrepair
      • Jul 2013
      • 13
      tom66,
      The tv works fine, as I am using a digital antenna via the coax input, and the converter box works for changing channels. I have been able to view the tv screen just fine for a years now. The problem is that none of the buttons on the remote or the top of the tv work at all, except on/off. In other words, I have no volume control, can't access the tv menu, input menu, etc...
        OK. First step is to get some pictures of the button assembly, as the fault may simply be a jammed/stuck button. Is the power button separate, or on the same board? If you have a digital camera, try pointing it at your remote -- an infrared remote light output is visible on most digital cameras as a white or purple light.
        • newtotvrepair
          • Jul 2013
          • 13
          All on the same board. Are you asking for a picture? Here it is.
          • newtotvrepair
            • Jul 2013
            • 13
            I pointed camera at both remote control and at tv IR sensor with no results
              Can we see the circuit board behind the buttons?
              When using the trick with the digital camera, you should press a button to see if there is a response. Make sure the batteries are fresh.
              • newtotvrepair
                • Jul 2013
                • 13
                I have fresh batteries and pressed the button. No luck. As for the inside view, I just had the tv apart and the button board is all one piece or so I thought (see photo below.) I just tested all buttons again and they all "click", so none are stuck.
                Here is a view of the power button and the button assembly (as per photos on ebay)
                  Stuck buttons can still be stuck internally even if they click -- in order to rule them out, you need to use a multimeter across them on ohms mode to see if pressing them makes them change.
                  Since your remote isn't producing IR, and assuming your camera doesn't have a very good IR cut filter (premium SLR will; budget compact won't), then you may have a second fault with the remote.
                  • newtotvrepair
                    • Jul 2013
                    • 13
                    It's a Nikon professional camera...it works
                    The reason I suspected the "main board" is because something definitely fried the moment I plugged in the HDMI cable off my computer. Do you think it could be something as simple as just the button assembly? It's only $15 to replace with a used one. BTW, the on/off button works from the remote control, so does that mean the IR works on it?
                      Yes since on/off works on remote that is probably working.
                      A stuck button can sometimes cause the TV to ignore other inputs e.g. from remote, but the power button is usually handled separately. It could be that when you reached around to plug in the HDMI you pressed and button and it got stuck. It would be unlikely that a power surge would do this.
                      • newtotvrepair
                        • Jul 2013
                        • 13
                        I am pretty careful with my actions, especially when connecting components. I was behind and below the TV to plug in the HDMI as that is where the connection is.
                        So, it is sounding like possibly a stuck/broken button assembly that is preventing the remote control's IR signal from being received at the IR sensor? It that what you're suggesting?
                        • newtotvrepair
                          • Jul 2013
                          • 13
                          BTW, as for the surge possibility, when I booted the computer with the HDMI cable connected the screen went suddenly blank and no other controls worked. It was definitely cause and effect..
                            Do you know how to test a button using a multimeter?
                            • newtotvrepair
                              • Jul 2013
                              • 13
                              Found this explanation: look at ur multimeter. put ur pointer at x1. now use ur test points as said above. press power button,meter should give some reading if not then power switch is defective(open).
                              Will have to open the TV up again. Do you think it could be anything other than the button assembly? BTW, thanks for all your help here..
                                That isn't relevant for a digital multimeter, but will work with an analog multimeter -- use the ohms range. If you don't have an analog meter post a picture of your meter.
                                • newtotvrepair
                                  • Jul 2013
                                  • 13
                                  Rather than going that route, can you just tell me if it is possible that the problem is anything other than the button assembly?
                                    There is a chance it is the main board.
                                    • newtotvrepair
                                      • Jul 2013
                                      • 13
                                      I've already replaced the main board with a new one, so is it safe to assume then that it must be the button assembly?
                                      In other words, are there any possible parts it could be other than those 2?
                                        I cannot think of any.
                                        • piipo
                                          Old Privileg 5.1 speakers remote control question
                                          by piipo
                                          Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                                          09-18-2024, 01:55 AM
                                        • hemant_2222
                                          Schematic for Denon Remote Control RC1156
                                          by hemant_2222
                                          Hello Everyone,
                                          Hope everyone is enjoying their repairs at hand!.
                                          I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
                                          I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
                                          Please refer to the attached picture, i think the voltage divider is missing...
                                          10-06-2023, 02:05 AM
                                        • tmhobadcap
                                          Pioneer VSX-522-K remote control not working???
                                          by tmhobadcap
                                          I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                                          At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                                          12-24-2020, 01:44 AM
                                        • Mc_Millian
                                          Toshiba 50lf711u20 fire tv remote not pairing
                                          by Mc_Millian
                                          I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                                          The Tv model number is: 50lf711u20 Rev B.
                                          I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                                          I've tried 3 different remotes which should be fully compatible with this TV.
                                          Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                                          The power button, along with the volume,back,select, and directional...
                                          04-07-2022, 12:15 PM
                                        • wolf1976
                                          wireless receiver for 6 speeds fan control with remote control
                                          by wolf1976
                                          hi i have a receiver that is destroyed from the overvoltage i guess
                                          my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                          the motor fan has not label
                                          i have an other receiver operational
                                          In your opinion can i measure the voltage at the output ?
                                          what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                          thanks in advance...
                                          07-23-2025, 03:12 PM
