Olevia 432-s12, blue light flashing, else, nothing.
  • lymon
    • Jul 2013
    • 9
    • usa
    Please be gentle with me, I am pretty much an amateur in electronic matters. Not totally ignorant, I know a capacitor from a hole in the ground, but don't have much experience in diagnosing problems, so any suggestions will be appreciated.
    My Olevia 432-s12 went out in the middle of a TV program. Trying to turn it back on, all I got was constant flashing blue light on the front panel.
    I removed both inverter boards, and found identical suspicious looking capacitors on both boards. Ends bulged, leaking. I replaced both capacitors, and replaced the boards. Nothing. Same issue, flashing blue light on front panel. So, while the capacitors may have been going bad, apparently they weren't causing the problem--yet.
    I am pretty much at the point where I start guessing some more, or ask you kind folks for some advice. Is it worth replacing the inverter boards? Should I try something else first? Help?
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: Olevia 432-s12, blue light flashing, else, nothing.
    can ya post some pictures of all boards? an what kind of caps ya replace them with? did ya get them from radioshack or some generic store?
    • lymon
      • Jul 2013
      • 9
      • usa
      The pics will have to wait a bit, until i can re-disassemble the TV. I put it back together until I realized that we really couldn't deal with watching a CRT TV anymore. Hopefully have the pics later today or tomorrow.
      The caps came from a local electronics supply house, the place where local shops go, when they need parts.
      • odewitt
        • Aug 2013
        This sounds like a mainboard problem.
        • lymon
          • Jul 2013
          • 9
          • usa
          Sorry for not posting in so long a time. I put the Olevia aside for a while, when I found a much larger Samsung on sale for cheap.
          This may not be as helpful as it could be, since I misplaced my list of parts, and took no pictures, but if anyone is experiencing the same problem I was having, it might help you at least get started in the right direction.
          The T.V. is working perfectly now. I'm not sure where I'm gonna put it, but at least it work.
          Initially I replaced 2 capacitors, one on the master inverter board, and an identical one on the slave inverter board. Both caps were obviously going bad, bulging, and one was leaking. Ignorantly, I assumed that these were, the problem, and reassembled the T.V. Nope, the caps may have been bad, but there were further issues, the T.V. still didn't work.
          I should have looked more closely at the main board while I had it out, as there were 3 more suspicious looking caps on that board under a metal cage. Anyway, after replacing these 3 caps, and reassembling, the T.V. came up like a champ, just out of the factory. 5 caps, total cost approx. $10, not a bad deal.
          • esqmooo
            HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
            by esqmooo
            Hello everyone.
            This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
            Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
            Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
            I tried long pressing on the power button, after several seconds it would go off then when the button is released...
            03-11-2025, 03:57 PM
          • Tomylee
            Nintendo 2DS XL – Orange light, no blue light, signs of overheating
            by Tomylee
            Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
            Here's what I've observed:
            All ribbon cables are properly connected
            Battery is present and in good condition
            No reaction even with screens disconnected
            There's a visible burn mark / overheating sign on the metal shield, right above the CPU
            I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
            06-26-2025, 02:33 PM
          • learnmore
            Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
            by learnmore
            Hello Community!
            CASE DETAILS
            Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
            13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
            Tried inserting firmware on USB and left it in for a few hours, but no change
            03-03-2024, 09:49 AM
          • CraigR
            Hp Spectra x360 Power light flashing, component id
            by CraigR
            Working on a hp x360 15-eb1043dx that will not turn on and the power light just flashes. It pulls 700ma when flashing. Under the thermocam I found a component I am unable to id that light up. If someone can help would be appreciated. I put the number that are on it in better test....
            05-07-2025, 11:06 AM
          • stephonwhyte
            un65tu7000fxza - Flashing Red Power Light
            by stephonwhyte
            un65tu7000fxza - I am experiencing the flashing red light on the power led. So I purchased the replacement kit for the mainboard and power supply. I still experienced the flash red power light. So I purchased a new ribbon cable, The flashing light stopped for a minute, I could hear sounds on the TV but no picture. I did the 60 second reset and it went back to flashing. What could possibly be the issue now? All the LEDs are lit up from what I can see.
            Thanks for all responses.
            11-22-2022, 12:03 PM
