Medion MD41527 PS b/d hissing/crackling noise
  • notallbad
    • Oct 2012
    • 1190
    Re: Medion MD41527 PS b/d hissing/crackling noise
    In my quest to beat this thing I am looking at replacing the Optocouplers marked P421F just out of curiosity. Once I come across a Viper that will be next on my list to change.
    Can these be replaced with either a Cosmo 1010 817 or a PC123?
    The PC123 looks like a good match comparing the spec sheets unless I'm missing something.
    • notallbad
      • Oct 2012
      • 1190
      Well replacing the Opto couplers made no difference.
      Perhaps try a 0.022uF 630v cap next? If I can find one. R75 MKP.
        http://www.ebay.co.uk/itm/Panasonic-...item20c4ce85a4
        • notallbad
          • Oct 2012
          • 1190
          Just dug out a 60" plasma PS b/d and found a cap with 223K630 printed on it so guessing this is a 22000pf 630v cap, suitable?
          The only problem I may have is the lead spacing.
            Yeah it should be OK.
            • notallbad
              • Oct 2012
              • 1190
              Shall have to keep guessing, still no luck, exchanged cap with same results.
              • notallbad
                • Oct 2012
                • 1190
                How can I eliminate the main board being the cause? i.e test the PS b/d standalone
                  I wouldn't consider a main board to cause this fault.
                  But if you want, you would use some car lamps to provide a load, probably two 65W headlamps in series on the 24V (65W total load), and one brake light on 12V. Then jumper PS ON to turn power supply on (using a 1kohm resistor to 5V.)
                  • notallbad
                    • Oct 2012
                    • 1190
                    First reading in stby, second reading when on
                    CN904
                    1 - 0.15 4.4
                    2 - 0 0
                    3 - 0 0
                    4 - 0.22 4.95
                    5 - 0.22 4.95
                    6 - 0.22 4.95
                    7 - 4.9 4.87
                    8 - 0 0
                    9 - 0 0
                    10 - 0 11.68
                    11 - 0 11.68
                    CN903
                    1 - 0 0
                    2 - 0 0
                    3 - 0 11.68
                    4 - 0 11.68
                    CN902
                    1 - 0 0
                    2 - 0 0
                    3 - 0 0
                    4 - 0 0
                    5 - 0 0
                    6 - 0 23.2
                    7 - 0 23.2
                    8 - 0 23.2
                    9 - 0 23.2
                    10 - 0 23.2
                    • notallbad
                      • Oct 2012
                      • 1190
                      What reading should I be getting on the Viper22A, pins 5 to 8? The Pcb has a darkened brown area around pins 5 to 8.
                      Don't seem to get a steady reading when using either mains neutral or the main cap neg leg. Or should the com probe be on the bridge rectifier dc output neg leg?
                        Pins 5 to 8 are probably the drain, in which case stable reading not expected. Viper chip is for 5V standby only. If the standby transformer is not source of hiss, I'd rule it out for now.
                        • notallbad
                          • Oct 2012
                          • 1190
                          There is a hiss when just on standby which isn't that audible but I'm sure its not normal.
                            A light hissing may be considered normal if it is inaudible from operating distance.
                            • notallbad
                              • Oct 2012
                              • 1190
                              On Pin4 of Viper theres 21.2v when tv in stby and 20.2v when tv is on.
                              Measuring between main cap neg leg and viper pin 4, Vdd.
                                That is fine.
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  Not sure this is normal though, but appreciate it is sometimes 'normal'.
                                  • notallbad
                                    • Oct 2012
                                    • 1190
                                    Heres an audio clip. Hopefully it will be clearer to you what the noise actually is, perhaps my description hissing/crackling is not very accurate.
                                    First when switching on mains power, then goes quiet but still has that 'normal' hissing then power on from stby.
                                    • notallbad
                                      • Oct 2012
                                      • 1190
                                      Would it be possible to lift the pri side legs on the 2 opto couplers (IC12 and 13, located under the small xformer and next to C72) and replace with a diode just to eliminate the sec side of this part of the cct? If so what size diode would be needed?
                                        If you did that... the power supply would either not start or go out of control and try to output a high voltage due to the lack of feedback.
                                        • notallbad
                                          • Oct 2012
                                          • 1190
                                          OK, so going back I mentioned the on/off rocker was replaced due to crackling/arcing when turning it on and off, what would have caused this?
                                          A power surge/spike?
                                          If this was the case what could be damaged thats now causing the current fault? Varistor, ok not blown but is it possible? Can I just temporarily bypass the varistor to eliminate it? Replace with a jumper.
                                          • badcappo
                                            Dead Thinkpad E15, hissing noise from BQ25710
                                            by badcappo
                                            Hello there, got a Thinkpad E15 on the bench, almost no vital signs. Only things: Power button white LED flashes several times when USB-PD gets connected (number of flashes varies from three up to twelve times, sometimes no reaction at all). Battery charge indicator LED stays orange. Most interesting is hissing / whining sound from Battery Charge Controller IC BQ25710 on the keyboard side of the main pcb. Board fuses tested and intact, no shorts found so far. BQ25710 is also the only thing on the board to become warm in thermal image (below 70 °C). Thanks for any hint.
                                            03-09-2025, 08:23 AM
                                          • tony359
                                            by tony359
                                            11-28-2023, 05:18 AM
                                          • BlackBeetle
                                            MEDION AKOYA S15450 MD 63650 MSN: 30030203
                                            by BlackBeetle
                                            Hello, I have a problem with a Medion notebook.
                                            https://www.medion.com/de/service/pr...etail/30030203
                                            MEDION AKOYA S15450 (MD 63650) A-DE N MSN: 3003 0203 with Windows 10 64x
                                            The keyboard makes random entries and I don't seem to be the only one. Someone on this board has the same problem. I had BIOS version 207 installed and the BIOS version that Medion Support offers here as 209.
                                            https://community.medion.com/t5/Note.../104097/page/2
                                            Bios Version...
                                            08-09-2024, 05:50 PM
                                          • MegaZAC
                                            Onkyo TX-SR805 noise in one channel
                                            by MegaZAC
                                            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                            There's some logic behind it. As soon as I select an input I get only left...
                                            04-23-2025, 10:09 PM
                                          • dicky96
                                            DynAudio DBM50 Monitor Speaker - loud hissing noise
                                            by dicky96
                                            Hi guys
                                            I have a DynAudio DBM50 here - it makes a loud hissing noise.
                                            It sounds just like an FM radio with no antenna (or tuned off-station). The volume of the hissing fades up and down, sometimes drops to almost nothing then comes back loud. It occasionally makes a loud bump noise too.
                                            It does this even with nothing connected to the audio input XLR
                                            Any suggestions?...
                                            11-09-2020, 08:45 AM
