PANASONIC plasma TH-P42X20A, SOS4,1,10,6,8
  • tw2005
    replied
    Re: PANASONIC plasma TH-P42X20A, SOS4,1,10,6,8
    Originally posted by tw2005
    My replacement boards arrived, nothing shorted on them so should be good.
    So looks like I have a spare good SN for comparison.
    100% sure your IC773 is bad. So have a good look at the schematic. IC771 the 5V reg now has a low resistance on the output. I've removed it and tested it as good put 15v in and produces 5.07V out.
    I suspect the opto PC16461 is now damaged which is going to be hard to work on because of the overhang of the heatsink.
    I can confirm the low 800ohm across 5V out of IC771 was due to the opto now blown. That's a bugger because it's not readily available, can't find a single datasheet, I know it's a NEC PS9856-2-F3-AX . Last time I had to get someone to buy it direct in the US and forward it which made it expensive.
  • tw2005
    replied
    So I've revisted my old SS to investigate why the IGBT replacement did not work.
    looks like those substitutes would work because I just swapped the RJP30E4 IGBTs from the wroking 50" board onto it and same problem.
    So I'm left wondering now where to look but I'm thinking maybe sustain control and maybe damaged octal buffer.
    So I swapped one of those and still the same.
    Mystery but I think this is where I leave it.
    Seriously, Who am I trying to kid.I can't be beaten now can I? Nothing learnt.
    I could not find a single discrepancy with the semiconductors which really had be baffled.
    I was thinking half the signal was missing or the like via IC241 which I hate trying to solder by hand, but as I mentioned no change there.
    So in a last effort out of frustration all I could come up with was maybe something simple as a resistor was open cct. Apart from around the blown IGBTs i had not really checked them all, did not see much point.
    The FET driver IC, I replaced just in case so very confident that was ok.
    I start measuring across tiny resistors starting at the signal end, all checking good so far. each time comparing with the good board.
    I get to R131, R132 tiny 100 ohm resistors which AA_UMH & AA_UML enter the fet driver at HIN & LIN or from what the waveform is generated.
    On the good board 100ohms a piece, on my board R132 100ohms, check, R131? R131, where the f is my R131?
    So I had no drive signal on HIN!
    So, for about 12 months I've had this POS collecting dust deciding whether to keep going or what.
    The truth is out, those substitutes would have worked, because there was nil change putting the original type in.
    Clearly when I was working on the FET driver IC, I must have had the iron resting on R131 and desoldered the little bastard.
  • tw2005
    replied
    ....................So got another board (SS) - fixed!
    So lesson here was using what I thought was a reasonable substitute IGBT, IRG7S313UPBF caused me grief (not proven yet ) RJP30E4 were the originals............................
  • tw2005
    replied
    Originally posted by flocko
    did you end up changing Q603 as i cannot see it listed on the parts you have listed as having failed
    no, that's a SMD transistor? Mine seems ok
  • flocko
    replied
  • tw2005
    replied
    For what they cost, really just as safe to replace them. Q818 I've had one bad not go short, 701,702 I find will be short. It will be interesting to see your list of suspects that show short.
  • flocko
    replied
    Not just my eyes thats gone but thats another story, Was just going to check every thing and get some before and after replacement readings,as when i replace SMD transistors like these i cover them with solder to get them off the board as quickly as i can, but testing them after in most cases will not give a 100% reading with all the heat that has been put though them, Flocko
  • tw2005
    replied
    Hi sorry just had the board in front of me and not looking at the schematic just around the top of the board near the other parts Q701/2 IC733 thinking must be round here some were? it will happen to you when you get to my age, any way just got my meter out and started testing IC 773 showing 113 ohms across pins 3-4, i went to test Q818 in diode mode and i think my battery must be on its way out as meter keeps showing full screen ever thing comes on as soon as you put the probes on any thing it was playing up the other day. so off for new battery Flocko
    yeah, I understand. my eyes are crap for this tiny work. The other check is 3-5 gnd-vcc but you'll have to remove IC773 and recheck IC771 anyway. i think 5.6k is the norm but you'd want to be sure the reg is good .
    must be that time of the month , my low bat is showing too but still reading ok.
  • flocko
    replied
  • tw2005
    replied
    Checked with the seller of those boards asked if they did not work could i return them, he told me they were from a set that had a cracked screen, but the set powered on and showed a mucked up picture and were half the price of the rest on ebay but would not take returns, i asked if he would test them for shorts and his reply was i dont now how? so back to the repair will get the board out and start checking it over as per your list of parts later today,i am having a job to find the 5v reg IC 771 and the opto PC16461(461) on my board?
    well if you're following a service manual which I hope you are, it's quite simple.
    To locate in the schematic use find and use the full identifier IC16771, to get the board location drop the 16.
    It's a SMD 3 pin device marked AE right next to the Sn2 connector, the opto is to the right , 8pin in front of the large heatsink.
    sounds like those boards maybe ok if it powered with no blinks but powering it up with a cracked screen and possible short is a bit risky.
    getting it right first time for repair is the challenge, I must have had a brain fart on mine because it appeared no harder than the 5081 I've done.
    But the extra damage sure looks familar so I still believe the inverter cct that drives Q661 is critical.
    That's Q701,702,818,D701,702, IC773,IC771, maybe shunt reg cct Q672,662,663 etc
    Either D701 or 702 intially showed short but cleared once I removed the shorted components around it.
  • flocko
    replied
  • tw2005
    replied
    Hi TW sorry to hear that, i now have all my parts to hand for my repair but was giving myself a bit more time before starting it.i will now double check every thing before i make my move.Your work will not be in vain and thanks again for all your help (those Ebay boards are sure looking tempting now) Flocko
  • flocko
    replied
  • tw2005
    replied
    I have a feeling I may have tested the wrong transistor for Q701.
    So confirmed bad.
    R707,Q701,702,818,661 IC773, possibly Q672
    Q401,Q402
    IC562 , because R707 flashbanged, that's connected to pin 17 and last time I had bad R707, IC562 was bad.
    Not sure if I'll persist with it or not because the Tv is working, just waiting on the correct SS board to arrive.
  • tw2005
    replied
    Just had a go at doing a quick repair of this TNPA5066.
    Q661 shorted on 2 legs
    D451 shorted
    D481 shorted
    Q702 shorted
    IC773 bad, resistance pins 3-4 128ohms, good reads over 2Mohms
    Q818 seemd ok in cct but replaced with 2N7002
    Q701 seemed ok and left
    Looking all good and similar to what I've done on the 5081.
    And, bang
    Now, it's really bad just like the last time I got it wrong.
    Q701 shows short. maybe I missed testing or mistested this, that I'll never know now.
    So, Q661 again dead, Q818 shows short, R707 blown, Q702 short, D701 short
    Now in cct Q421 short, D421 short, D401 short, Q402 short, Q401 short,
    IC771 5v reg now showing shorted output, that powers the inverter IC but was not shorted originally.
  • flocko
    replied
    Thanks again TW, i have them all on order now i found some 2SK3018 the only missing part now is the panasonic DSA200iS0L for Q603 but will keep looking should be with me mid week,The IGBTs for the SS board i hope will also be here this week Flocko
  • tw2005
    replied
    These maybe correct size. You'll have to check. I got the wrong size and still managed to just solder it in.
    2N7002 is pretty common , original is 2SK3018T106 size is UMT3 or SOT323. Again up to you to be certain.
    http://uk.rs-online.com/web/c/semico...8&m=1&aaaExp=Y
  • flocko
    replied
    Thanks TW i did not think to see if there was a sub on that,i can now get all now apart from DSA2001S0L over here. As for buying 100 i would put the rest on Ebay only need to sell one for a £1 to get my money back and could make £99.00 if i got lucky.
  • tw2005
    replied
    Sn74ahc1g14dbvr
    RS UK pack of 25
  • tw2005
    replied
    Thanks for part numbers,have been looking for the TC7SH14F no one has this any were over here same with the DSA2001S0L, the others i can get for about £1 each over here or £1 per 100 from China,i will see if i can get some TC7S14F and the DSA2001S0L also from china i am in no rush to get the set running Flocko
    TI have an exact replacement for the toshiba. RS UK have the other, Hope you can use 100 over time.
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • Hakuu
    by Hakuu
    Hi There,
    More Details
    TV Model - LG OLED77G1PUA
    07-12-2023, 02:37 PM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
