Samsung LN46c650l1fxza no blacklight
  • evilhero
    • May 2011
    • 17
    Hi, I have this problem with this tv. It will power up with 5 red led blinks. It will plays the samsung chiming sound but no picture or light. I can power it back down and it will played the chiming off. The model of powersupply is bn44-00341b, mainboard: BN41-01436b, inveter: t871070.00 I check the power while the power is ON.
    CN802:
    Pin1 B13v: 12.85v
    Pin2 Lamp_det: 0v (jump to 3v than go down to 0v)
    Pin3 B13v: 12.85v
    pin4 sw_inv: 5.10v
    pin5 b13v: 12.84v
    pin6 pwm_dim: 0.84v
    pin7 ground: 0v
    pin8 h_sync: 1.73
    Pin9 ground: 0v
    pin10 ground: 0v
    Pin11 b5v: 5.11v
    pin 12 ground: 0v
    pin 13 b5v: 5.11v
    pin 14 b5v: 5.11v
    pin 15 13/18vs: 12.85v
    pin 16 A5v: 5.11v
    pin 17 13/18vs: 12.86v
    pin 18 power on/off: 0.87
    CNI802:
    Pin 1 12v: 12.78
    Pin 2 fb: 0v
    pin 3 fb: 0v
    pin 4 gnd: 0v
    pin 5 gnd: 0v
    pin 6 LD: 9v
    pin 7 LD: 9v
    CNI801:
    checked 0v ac
    The cap seem to be okie no budge on the psu.
    Re: Samsung LN46c650l1fxza no blacklight
    There are one or two large 450V capacitors on the power supply. With a volt meter on the highest DC range check the voltage across them.
      Schematic for power board
      • evilhero
        • May 2011
        • 17
        The reading on both cap is 382v.
          Any pictures of the boards? The PS_ON and the PFC Voltage booster is working OK otherwise you will not have the 380VDC on the main filter caps.
          • evilhero
            • May 2011
            • 17
            I cannot really tell the black light never flash. Just hear the samsung starting up chiming. Already attempted looking for bad transformer by checking the secondary wind with an ohms meter. All of them are the same measurement resistance. The psu unit seem to be cranking out the right amount of voltage. Do you think it is the mainboard telling the inverter board to be on protection mode? Thank you very much for helping me! budm =)
              Can you check the line marked BL ON?
              Consider JP852/JP854 jumper cut - can help solve flickering backlight but maybe also no backlight?
              • evilhero
                • May 2011
                • 17
                I cannot see any marking on the mainboard call BL ON. I did removed the jp852 jumper with the same result. I read an older post when you disconnect the mainboard. The psu and inverter board will turn on the blacklight because the bl on will be missing. Unfortunately that step also fail. I'll cut JP854 tomorrow. My problem is similar to this thread: https://www.badcaps.net/forum/showth...ighlight=bl_on
                until the lao guy hijack to something else.
                  On this it is SW INV.
                    "pin4 sw_inv: 5.10v" So the BL-ON (SW INV) signal is OK. Per digarm, there is a fuse (FS802S) for the B+ (PFC) for feeding the Inverter circuit, is it OK?
                    So this TV has the Balancer board?
                    • evilhero
                      • May 2011
                      • 17
                      The fuses FS802s tested good and sw_inv pin 3 on psu measure: 5.08v "poweroff standymode": got 0v. Also tested FS801s to be good.
                        Check the voltage across the exposed terminals of C1842 (there may not be a component here but you should be able to probe across the holes.) A low voltage here indicates a shutdown due to under-voltage lockout.
                        • evilhero
                          • May 2011
                          • 17
                          The c1842 reading from a hot ground point read: 59v
                            Please measure across the positive and negative terminals of C1842. Red probe one end, black on other end.
                            • evilhero
                              • May 2011
                              • 17
                              this c1842 is the mainboard or psu?
                              • evilhero
                                • May 2011
                                • 17
                                opsss.. was measuring c1802.. found the c1842 reading as 3.75v
                                  OK, that would appear to be OK.
                                  With the black probe on the negative lead of the large 450V capacitor, what voltages do you measure on each end of the fuse FS802S?
                                  • evilhero
                                    • May 2011
                                    • 17
                                    yeah, I probe the fuse on both end check out to be 378v. what else do you want to check?
                                    • evilhero
                                      • May 2011
                                      • 17
                                      I took a picture of the powersupply and did some more testing on the inverter high AC side. all the transformer point test at 150-230 ac which is similar to cni801. I saw a video where u can jump the powersupply sw_pwr with another pin to get the lcd tv black light on without the mainboard. If so what is the pin do I short together pw_sw?
                                        It has built-in pull-up resistor already, all you have to do is to disconnect CN802.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
