Top part of screen has big black bar and from middle on down the information like from the OSD is rolling continously toward the bottom.I've never seen this so it will be worth the $20 I gave for it to learn what causes this.I'm thinking it's probably the main board or T-con or could it be the panel since it affects the OSD?
Rca l32hd31r
by sureshbobbyDear Friends,
I have issue with dell latitude 7240 in which Laptop hdd led is continously blinking. Please help03-10-2022, 02:58 AM -
by dicky96Hi guys
So after best part of a year doing other stuff, I'm back to master this BGA reworking, 2nd time lucky I hope
So I thought the best place to start was with the steps that were giving me problems last time.
With this type of reballing jig and stencils:
https://www.aliexpress.com/item/3303...archweb201603_
by CoinCoin88Hello everyone,
I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver... -
hello i bought a faulty radeon r9 290 (black screen) to learn to fix gpu's, when it arrived i mesured resistances on 3.3 v and 12v both on the pcie connector and cables i have no idea on how to recognize 1.8v pex and 5v but i checked all inductors and none had a dead short only one was 55 or 140 ohms i don't really remember and i assumed it was memory i installed it on the pc and it delivered no image, not even a backlight so i installed it as a secondary graphics card using the igpu as primary, both device manager and gpu-z only showed the igpu so i assumed it was acutally a no detect even tough...
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
- Loading...
