Magnavox Model 37MF231D/37 dead
  • AlRad
    • Jun 2013
    • 8
    This TV is dead. After reading some of the technical material on this forum I measured all the pins on the IR/on-off board and there is no voltage present on any of the pins. My understanding is that there should be a %VDC standby voltage here that is used to initiate the other TV functions at turn-on.
    I got this TV from my brother-in-law who said it just stopped working and he was going to throw it away. So I am using it as a learning opportunity and trying not to use it for target practice.
    I inspected the p/s components and found nothing obvious; no burned parts, buldged caps, or broken components. The TV had been worked before by an unknow technician and the board shows where two cap were replaced (not factory soldering). I don't have a schematic and couldn't find the manual on toms-service-manuals listing. I found a 42MF231D_50MF231 but not similiar to mine.
    The pictures are of the under side of the p/s with part number. One picture show 1200/35v and 2200/25v written on the chassis but I couldn't find a 1220ufd 35v cap on the board.
    I would appreciate any help in repairing this TV.
    Thanks, AlRad
    Re: Magnavox Model 37MF231D/37 dead
    Can you post a picture of your model # sticker this will have a chassis code like Q523.LA on it which is used for service manuals.
    • AlRad
      • Jun 2013
      • 8
      Here is the picture of Model# sticker.
        TPE1.0U-LA then.
        • AlRad
          • Jun 2013
          • 8
          Thanks Tom66 for the info. i will update when i find anything. I didn't see a cap kit for this tv on the forum. Do you have info or source for the caps?
          • aaronwt6
            • Apr 2013
            • 855
            • US
            http://www.ebay.com/itm/230677099638
            I just did the swap out myself on one. I'd be skeptical if its the caps or not if you are getting absolutely no voltage on the standby pins. Mine would at least turn on for a bit til it got hot. Also, the light on the front should glow without powering up the TV.
            • aaronwt6
              • Apr 2013
              • 855
              • US
              Here's a couple complete PS's on Ebay for around $30.
              http://www.ebay.com/itm/Philips-mode...#ht_133wt_1399
              http://www.ebay.com/itm/313815866811...7#ht_64wt_1161
              • AlRad
                • Jun 2013
                • 8
                I've been trying to figure out the manual which contains info for 26", 32",37", and 42". It seems to apply mainly to the 26" with reference to other models. It does contain a 37" and 42" supplemental material for the P/S. Using the P/S info and probing the board I found that on the
                1089 connector to the Main Board:
                pin 1and 2, 16v is reading 11v
                pin 3, 24A is 24v
                pin 4, Bright adjust is 0.788v
                pin 5, Inverter on-off is 0.003v
                pin 9, standy is 0v
                pin 6, 7, 8, and 10 are ground
                connector 1088 to the Inverter Board:
                pins 1-5, 24v is 0.158v
                pin 6, Bright adjust is 0.787v
                pin 8-12 are ground
                The p/s 16v reading 11v and no 24Av on 1089 pin 3 and no standyby voltage would seem to be a p/s problem but I don't know the start up sequence of this unit. Looking at the schematics it appears that the Main Board supplies the standby voltage to the IR card and the p/s. I am still looking for the schematic for the "Main Board".
                I don't mean to ramble, just trying to make sense of 128 pages of info and find the right clues.
                Does this info indicate a definite p/s problem or do I need to supply more info? If bad p/s is the answer I will go to ebay as aaronwt6 suggested.
                Thanks, AlRad
                  HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                  This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 05:27 AM
                  HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                  This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                  HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                  This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                  This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                • ptcriserx3
                  toshiba crt tv model mv20fm3 100% dead
                  by ptcriserx3
                  hi
                  ive got an old 2002 toshiba crt tv
                  its 100% dead
                  no power on
                  no standby light
                  no click sounds
                  nothing
                  ps main fuse checks ok
                  caps not bulged
                  what would be most common failure to cause this?
                  10-09-2023, 05:03 PM
