Hello:
I've been using this site for awhile to help me resurrect TVs and monitors.
It's a great resource
This is my first time posting.
My goal is to get this TV working, but more importantly, I am trying to learn something to improve my troubleshooting skills along the way.
Symptoms: LN-S2651D Chassis GBD26KU
As soon as I plug the TV into AC the power light will flash 4 times ( 1 flash per second) and then extinguish. After approx. 5 seconds, the cycle will repeat endlessly.
Pushing the power button (I don't have the remote) does nothing. I get no sound, picture or back light.
Observations:
Several components (tuner, Main CPU) on the main board (BN97-00827A) are warm to the touch.
The capacitors on the power supply (BN96-03060A) do not appear to be bulging or vented.
I have not removed them to test…yet.
When I unplug connector cm1001 from the main board, the back light will come on. They stay for the entire 4 light blinking cycle and briefly extinguish at the beginning of the next blinking cycle and then come back on.
I managed to get a copy of the service manual and followed the first troubleshooting flow diagram (see attached). All voltage test points check out until I can to box #6.
These are the voltages I say:
Location-------Should Be------------Actual
C108------------B9V----------------13.30V
C110------------B8V-----------------7.99V
C123------------VCC5VP-------------.299V
C128------------B3.3V_1-------------3.36V
C135------------B3.3V_2-------------3.32V
C133-------------5V_VCC-------------5.37V
Clearly I am not seeing 5 volt VCC and C109 is high (13.30V)
I looked on the back of the main board and located IC 103 (4435B). It appears to be a MOSFET power switch for the 5 V VCC rail. I checked the voltages on the pints of IC 103:
Pin# Value
1---5.38V
2---5.38V
3---5.38V
4---5.32V
5---.295V
6---.295V
7---.295V
8---.292V
In the picture you can see I flipped the power button PC board over so I could access the power button and see the led when the TV is face down on the bench.
When I press the power button, I can see the 3.3V present on the cable (yellow wire) go to ground.
I was able to get a main board schematic for a LN-S3292D. I thought it may be similar to the LN-S2651D
I am unable to trace how the signal for the power button translates into turning on IC 301 and providing power to the 5 volt rail.
There is a transistor Q 101 next to IC 103. I see 5.3 volts on the collector and 0 volts on the base and emitter. I see nothing on the base when I push the power button.
Assumptions:
I believe that the power supply if OK. It seems to be providing 6.2 V standby, as well as 12V, 5V and 24V.
The main reason for no 5V VCC is that IC-301 is not switching on the 5 volt rail, but on this I am not sure.
Any further things that you guys can suggest that I test would be greatly appreciated.
Observations:
Pin# Value
1---5.38V
2---5.38V
3---5.38V
4---5.32V
5---.295V
6---.295V
7---.295V
8---.292V
Assumptions:
