Samsung UN55D6450UF - Lightning Damaged
  • ndoggfromhell
    • May 2010
    • 24
    Re: Samsung UN55D6450UF - Lightning Damaged
    Meter set the same as before?
    • ndoggfromhell
      • May 2010
      • 24
      12.58 and 5.38 were the measurements at those two pins
        OK, power board is fine, so main board is more than likely the fault.
        • ndoggfromhell
          • May 2010
          • 24
          Are the T-Con boards interchangeable between models as long as the board has the same numbers? The one I purchased is for a Samsung UN55D6400 but mine is a UN55D6450. The boards look identical and have the same number in the upper right corner.
            Should be no problem.
            About Samsung model numbers: Often, it is only the UN55D64__ part that is important. The "00" is probably a generic build, whereas the "50" is a variant build. The variant could be as simple as slightly different start up settings, different remote supplied with unit, maybe different bezel (plastic vs metal, different shape etc.) or set up to be more attractive in a different retail situation like a large warehouse (higher brightness and colour settings.) Typical in warehouse clubs (Sam's, Costco, etc.) The reason for doing this is because it reduces the ability for consumers to cross-compare prices and also stops the larger chains (Best Buy etc) getting angry that the same model is available for less from a warehouse club... because it isn't the same, it's ever so slightly different. Panasonic are known to do this too, e.g 50" plasma S60 for everyone else, S64 for Costco/Sam's.
            • ndoggfromhell
              • May 2010
              • 24
              #26
              at this point should I return the T-con board and request a new one? Seller on ebay seems reputable. http://www.ebay.com/itm/Samsung-UN55...item4d06c57fea
                Both T-cons are probably OK.
                Both main boards are probably bad.
                • ndoggfromhell
                  • May 2010
                  • 24
                  #28
                  The mainboard being the one with all the inputs correct?
                    Yes.
                    • ndoggfromhell
                      • May 2010
                      • 24
                      #30
                      We have been unable to source a new main board for this Television. repairs are on hold until we can produce one.
                        09-07-2024, 05:50 AM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
                        Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                        This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 06:20 PM
