Panasonic TX-P42S21 dark picture
  • marekk
    • Mar 2013
    • 36
    I'm trying to fix this panasonc plasma TV.
    TV has got very dark almost invisible picture from all sources like HDMI, tuner or scart but OSD/menu works fine. I have narrowed the problem to main AV board TNPH0845. This board is pretty difficult to get and expensive. Have anybody fixed to component level that kind of fault?
    I will appreciate any help
    Best regards
    Marek
    Re: Panasonic TX-P42S21 dark picture
    Personally I would be more leaning towards the SS or P board.
    • marekk
      • Mar 2013
      • 36
      I have replaced main board with TNPH0838 from TX-P42G20 and picture was OK. This is why I think it is main board problem.
        Sorry, completely missed the bit where you said the OSD was fine.
        In the service menu, there are options for W-GAIN, R-GAIN, B-GAIN, G-GAIN, etc. Have you tried adjusting them? Perhaps compare with G20 for values.
        • Bazfletch3
          Panasonic TH-65FX800A backlight LED's working but picture is very dark
          by Bazfletch3
          Hi all
          While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
          I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
          From there I envisaged that the backlighting wasn't working, however...
          01-08-2024, 10:18 PM
        • Danstona
          LG 65UK6090PUA - picture dark
          by Danstona
          Was watching this set, and suddenly it went dark. Picture is still visible, just very dark. Tried checking all settings, adjusting brightness to 100% no change. Reset through menus, no change.
          bought used boards from ebay (power and input boards) replaced with same results, changing brightness does seem to have a slight affect.. but not to normal visibility of picture.
          I'm handy, fixed TVs before.. I can't see any issues with boards... hoping someone can point me in the right direction to properly diagnose. I don't believe the LEDs are caput, since the picture is on and equal...
          03-10-2024, 12:41 PM
        • FZG
          Panasonic AG-1000B VHS player with bad picture quality
          by FZG
          Hello!
          I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
          Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
          I want to know, is this something that could be solved by recapping or is the video head likely gone?
          Also, what mechanism is this?
          Any feedback is appreciated!...
          05-06-2024, 07:16 AM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
