samsung pn51d450 odd problem
  • Nixpaints
    • May 2013
    • 7
    • US
    Love the input on this forum, great work.
    Need help, my samsung plasma picture went out. It has the dim/pixelated screen that is typical on a failed x-main board, but in addition it has a odd warped black area at the bottom of the screen. I replaced the x-main and the symptoms remain unchanged. I have thoroughly inspected the screen itself for damage and don't see any.
    Anyone ever seen anything like this?
    Re: samsung pn51d450 odd problem
    I saw this a few months ago with exactly the same failure, very odd.
    I'm pretty sure the panel has a small crack in it and has leaked gas in that area. Maybe the crack damaged the X-main too. Not really repairable. And the crack can be behind the frame, on the edge of the internal glass, it may not necessarily be visible.
    • Nixpaints
      • May 2013
      • 7
      • US
      Thats what I was thinking but I did remove the frame and inspect the edge of the glass, no signs of damage whatsoever.
        Perhaps the glass layers are separated and the gas has leaked from that area. I can't see any of the boards in the set causing this.
          09-07-2024, 05:50 AM
        • howardc64
          Samsung UN55JU650DF network/streaming problem
          by howardc64
          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
          07-09-2025, 12:44 PM
        • alro7779
          Samsung UN55MU6103F video problem; has colored stripes on the display
          by alro7779
          Hello, everyone!
          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
          09-27-2025, 11:29 PM
          09-06-2024, 11:40 PM
