Need Help! Samsung LCD TV LN46C630
  • nomoresonys
    • 12331
    • U.S.
    Re: Need Help! Samsung LCD TV LN46C630
    from the pleasant dialogue and good wishes chirp relayed, I would have bet he would have FOLLOWED UP....WHY CHIRP WHY?
    • gitster
      • Jun 2015
      I have this same issue. Red status light stays on but no response from tv.
      Backlights turn ON when black cable between main board and BN44-00341B are disconnected. No backlighting when ribbon cable removed from top board (t-con?) which runs to main board. Seems to point to bad main board?
      FYI, I had this tv plugged into a squid type power distributor during a thunderstorm, which I assumed was a surge protector, I guess I assumed wrong as this is what damaged my TV. The problem occurred immediately after our power flickered 4 times during the thunderstorm.
      Are there any tests I can do on the main board with a multimeter to ensure this is the problem? Also, to make sure my terminology is correct.... the main board is the board with all the audio and video inputs?
        09-07-2024, 05:50 AM
      • fixit007
        Samsung flicker - BN44-00932T board or else?
        by fixit007
        I picked up this TV that the prior owner said - just died.
        Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
        Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
        Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
        05-04-2024, 06:14 PM
        09-06-2024, 11:40 PM
        09-06-2024, 08:40 PM
