LG 37LC2D Major S/C Testing F9223L
  • signup
    • May 2013
    • 189
    hi
    Was going to post in the other 37LC2D post but that one semed more related to the very common LG cap failure
    Anyway, got this tv and found the Bridge S/C cant see anything else on board and wondered if anyone can give me a pointer on how to test the 13 legged I/C , I have already removed it from the board
    Thanks in advance
    Re: LG 37LC2D Major S/C Testing F9223L
    What's the part # of the device?
    • signup
      • May 2013
      • 189
      Sorry Tom, I only put the part number in the title F9223L (Datasheet attached)
        Test for shorts (both ways):
        23 to 20
        23 to 19
        19 to 4
        7 to 8
        Any short circuit indicates a fault.
        • signup
          • May 2013
          • 189
          Cheers Tom...23-20 23-19 s/c'd
          Going to order one now
            If that internal FET failed short inside the device, you may also need to test external devices. I don't know how it is connected because the second fet seems to be floating -- for external use. Not sure why.
            • signup
              • May 2013
              • 189
              The only other thing I can see was the bridge, If I remember rightly they normally take a couple of the small smd caps and resistors on the underside, but these seem to be ok, I found another old board with the part in thats fine so going to pop it in later
              Will let you know how it goes
              • signup
                • May 2013
                • 189
                Hi
                Fixed with a different fault
                replaced the Bridge/F9223L and recapped the secondary side, the problem I am having is with the sound and digital tv. The speakers keep crackling and when you try and tune in Digital channels it refuses to start, I could get round this by doing a factory reset so it searches for analogue then digital but its not jumping to channel 21 or even trying to search for digital.
                I have another TV that is fully working, as soon as I put the psu int the working tv I get the same problems...so I know it has to be something on the psu
                Any help appeciiated
                • signup
                  • May 2013
                  • 189
                  Sorry should of added my 3.4 line is down at 1.83v
                    If your 3.4V is low, you will get those problems.
                    The controller IC on 3.4V is failed or the capacitors around it are bad.
                    • signup
                      • May 2013
                      • 189
                      Cheers Tom
                      I have changed the two fets and regulator on the underide of the board but still the same.
                      Any other pointers
                        Did you change the ones for the 6V or 3.4V?
                        • signup
                          • May 2013
                          • 189
                          3.4 as shown in budm diagram on the other post..I will just go an check the 6v line now
                          • signup
                            • May 2013
                            • 189
                            I am getting 6.1v
                              Check what 3.4V rises to when you disconnect the main board connector -without- the POWER ON signals (PSON, BLON etc.)
                              • signup
                                • May 2013
                                • 189
                                I have just been looking throough the other thread regarding this tv and there is a little contradiction Budm shows a picture of 3.4 buck and fets but then later in the post you say this is the 6v line and the 3.4 volts is to the left of the board...bit confussed now
                                Is the 3.4 v line by the inverter plugs or is that the 6v line...I think I have replaced all the 6v fets and ic
                                • signup
                                  • May 2013
                                  • 189
                                  Budm Put
                                  https://www.badcaps.net/forum/showth...t=18218&page=5 post number 81
                                  You put
                                  https://www.badcaps.net/forum/showth...t=18218&page=6 Post 103
                                    You can trace it through the inductor and capacitors and find the 3.4V one. I no longer have this TV or board in my possession.
                                    • signup
                                      • May 2013
                                      • 189
                                      I have uploaded the two pics, on your pic you say the 3.4 is to the left but budm says his pic is the 3.4v ic and fets which is the one on the right of your pic...confused...I am too.
                                        In the middle/right of the first pic.
                                        Budm's left is different to your left?
                                          MEDION ERAZER Major X20 Notebook Specification for Upgrade or Repair
                                          This specification for the MEDION ERAZER Major X20 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Major X20 boardview and Major X20 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                                          09-07-2024, 06:31 AM
                                          MEDION ERAZER Major X10 Notebook Specification for Upgrade or Repair
                                          This specification for the MEDION ERAZER Major X10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Major X10 boardview and Major X10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                                          09-07-2024, 06:11 AM
