Samsung LN-32C540 32" LCD - Standby Light Stays, Buttons Not Responsive
  • flournnoi
    • Apr 2013
    I have a 32" Samsung LCD T.V. - LN-32C540 that was made in 2010. The t.v. won't turn on. When it is plugged in an outlet, the standby light is on but does not blink. The t.v. does not respond to the remote control or the touch sensitive buttons on the front of the t.v. panel. There is no "buzzing" sound or other audio feedback like many people are having with blown capacitors. I've opened it up and I can't see any blown capacitors, but there are 10v 2200s on the board. I was thinking it might be either the control board or the power/IR board. Has anyone had this combination of symptoms with blown capacitors? I have scoured the internet looking for a resolution to this, but many of the threads that have issues like this don't have definitive responses. I don't currently have a meter to test with so I was hoping that there might be some way of diagnosing it without this equipment, but I understand that's a little tricky. I really appreciate any help that anyone can give me on this!
    Re: Samsung LN-32C540 32" LCD - Standby Light Stays, Buttons Not Responsive
    You will need a multimeter at a minimum to diagnose a power supply. Measure the voltage on each of the power supply outputs and see if the outputs are low. If the outputs are low (but not near zero), there is a chance the capacitors are bad. Capacitors can and do fail without bulging.
    • Artelis
      • Jul 2014
      • Latvija
      Hello guys,
      Maybe someone can help me. I change main board for my samsung le32 but after that no any button respond. Only when push power button can hear short sound signal as usualy touch some of touch buttons but nothing hapening. Can it be some software isue?
        09-07-2024, 05:50 AM
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • ChristianBr01
        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
        by ChristianBr01
        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
        04-23-2025, 01:48 AM
      • Kaar3l
        Samsung QLED QE65Q7FNAT only standby light
        by Kaar3l
        TV: Samsung QLED QE65Q7FNAT
        PSU: BN4400940A
        MB: BN94-12832K
        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
        09-24-2024, 01:35 PM
        09-06-2024, 11:40 PM
