slow power flashing HP LC3760N
  • nankipoo
    • Mar 2013
    Steady slow flashing power led, no picture.
    Flat screen tv HP LC3760N
    Was told power supply likely even though none of the capacitors looked blown I decided to give that a try.
    I replaced the power supply and you guessed it, same thing slow steady flashing led and no picture.
    Any Ideas of what to check?
    Lowell
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
    03-31-2024, 02:12 PM
    09-06-2024, 05:59 AM
  • meraklinetx
    Asus Z97-a power cycle, no boot no cpu voltage
    by meraklinetx
    Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
    05-10-2023, 06:08 AM
