Samsung lcd LE32R81B
  • soul1988
    • 19
    • portugal
    I have a 32 samsung lcd tv model ln32r81b and power it on it will blink 5 times red power light then the screen lightup for a second and go off.the power supply the tv has is a BN44-00191A i will post pictures of the power supply and tv.Any help will be appreciated thanks.
    Re: Samsung lcd LE32R81B
    Here is the SCH of the BN44-00191A: just fill in the boxes
    http://www.tgohome.com/ServiceManuals/
    Check the PWR_ON/OFF pin, it should have >3V when the TV is turn on
    Same for BL_ON pin.
    • soul1988
      • 19
      • portugal
      I checked the voltages on the connector that is marked in the image, not sure if this is the right connector to check voltages.
      ON/OFF- 3.65V when I connect the power cable and 2.46V when backlight flashe.
      B/L- 0.004V when I connect the power cable and 5.72V when backlight flashe.
      • soul1988
        • 19
        • portugal
        I checked the voltages on the 24V rail for backlight and the voltage is 27V is this normal?
          The main key is that the ON/OFF and the BL_ON still stay >3V AFTER the backlights go out? ON/OFF and the BL_ON are generated by the main board.
          Check you batteries of your meter.
          • soul1988
            • 19
            • portugal
            The ON/OFF -3.65V and the B/L-5.72, I'm not sure if I'm in the right place to test, I marked the place in the photo that I'm testing. I do not have BL_ON in the board.
            • soul1988
              • 19
              • portugal
              I tested all capacitors on the board, all are within the expected values and low esr
              • soul1988
                • 19
                • portugal
                Problem solved, it was the inverter board, a transformer was damaged.
                • soul1988
                  • 19
                  • portugal
                  Once again is broken, this time i read 30V on the voltage for the inverter board and should be 24V, the measurement was made with the inverter board disconnected. This means that the problem this time is in powerboard right?
                    Check and replace your multimeter battery. A low battery can lead to erroneously high readings.
                    • soul1988
                      • 19
                      • portugal
                      battery is ok.
                        What voltage does the 5V standby measure?
                          09-07-2024, 05:50 AM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 06:20 PM
