I have a Samsung TV LN46A650 which was connected to a PC. It had recycled itself a few times. At that time I thought this was an issue with the video card getting too hot and I shutdown the computer and after sometime the problem would be gone. This issue would happen very rarely. However, I connected it to a Roku box about a month ago and it has started turning on and off more frequently. I thought it was the capacitor problem that people were talking about and called Samsung. They sent a technician who said that all my capacitors were fine. he replaced it anyway but still my TV keeps giving me the same problem. I tried connecting my laptop to the TV and that has the same problem. It won't even work when connected to an aerial. Sometimes it will work for sometime and then randomly switch on and off. Sometimes it will make a jarring sound and then turn off. I checked the power supply with a multimeter and tried HDMI and AV output ports and also different power supplies same problem.
I opened up the TV and with a multimeter I tested the voltages produced by the Power Supply board and saw that only PIN 3 produce 5.19 V all the other ports showed a solid 0. I was wondering as to how can this be the case since my TV does recycle but still does turn on sometimes. Other thing the board is labeled as 'IP-271135A' which translates to 'BN44-00202A' but shopjimmy.com says this is a substitute for 'BN44-00203A'. Is the problem that Samsung put a substitute part in my TV instead of the real one. I am going to buy a new power board. Which one should I buy the 'BN44-00203A' as specified by shopjimmy.com or the existing one in my TV 'IP-271135A'
