Samsung LE37S81B only start up once
  • PowerAmpFreak
    • 982
    • Sweden
    Samsung LE37S81B, strange behaviour...
    Only sign of problem was secondary cap in standby supply.
    Replaced, start it up, working perfectly.
    UNTIL it's either shut off by user OR shut off by itself if signal isn't applied (the normal minutes)
    When try to restart it - front red led flashes two rapid times and then you will get no attention from it. Doesn't matter if using remote or side keys.
    Is there a known issue with corrupt eeproms on these ?
    (as a result of bad cap in standby supply)
    You have to cycle power, and it will start again once and the same procedure.
    EDIT: I just noticed sometimes it is possible to start a few times - then returns to the "locked" state.
    Last edited by PowerAmpFreak; 01-17-2013, 11:16 AM. Reason: Additional information
    Re: Samsung LE37S81B only start up once
    Yes, do a reset. I have seen this before with buggy eeprom.
    European model (from standby): Info - Menu - Mute - Power. Then find reset option and select it.
    • PowerAmpFreak
      • 982
      • Sweden
      Update: I did a reset in service menu - no help
      I also disabled the watchdog - no help
      I replaced the eeprom to initiate a new memory download - no help
      So, I believe this is actually caused by the PSU. I can see a pattern of behaviour.
      From cold, it seems possible to start it up. As soon as the unit heats up, restart will be impossible (but if it's ON it will stay ON)
      It's possible to start up the set several times during the first minute from cold.
      So obviously something heats up and don't want to play anymore.
      When set is plugged in I can hear a whining high frequency sound coming from the main SMPS stage (not the standby supply) which sounds like an unstable voltage regulation loop.
      Since the set can be kicked on from cold there is little chance this is caused by bad caps. More to the point of cold joints.
      The thing is that I already touched up some joints, but I have to check for more.
        Some poly capacitors can fail when they get hot.
        Pictures would be appreciated.
        • PowerAmpFreak
          • 982
          • Sweden
          Today's update: (picture will come soon)
          I monitor the +24V line from the BN44-00157A powersupply during start-up.
          When the set will operate OK, the +24V line will come up very fast and stable.
          The time the set will fail to start, the +24V line jumps to +8.7V and stay there two seconds. Then drops.
          I assume mainboard will hang just because of this.
          So, it boils down maybe the F9222L controller will fail to start properly when hot.
          This could be one of the reasons.
            Consider startup capacitors, feedback IC, and any nearby poly-film capacitors. Pictures would help. If you get the BN44 number I may have a schematic.
            • PowerAmpFreak
              • 982
              • Sweden
              I replaced the erroramp (TL431) and associated optocoupler.
              Crossed fingers, it *appears* to startup every time from now on.
              I already replaced startup caps and filtercaps to F9222L just in case.
                09-07-2024, 05:50 AM
              • tvguy12012012120
                by tvguy12012012120
                02-07-2025, 05:13 PM
              • ChristianBr01
                LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                by ChristianBr01
                I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                04-23-2025, 01:48 AM
              • Kaar3l
                Samsung QLED QE65Q7FNAT only standby light
                by Kaar3l
                TV: Samsung QLED QE65Q7FNAT
                PSU: BN4400940A
                MB: BN94-12832K
                I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                09-24-2024, 01:35 PM
                09-06-2024, 11:40 PM
