philips 50pf7220a/37 (bad caps)
  • tocold4u2
    • Dec 2012
    • 284
    • usa
    Re: philips 50pf7220a/37 (bad caps)
    model chassie is s50hw-xbo3 and the PDP IS S50HW-XD04 YES THOSE TWO WHITE POTS IS WHAT I WAS TALKING ABOUT
      OK, since it's not labelled which is Yrr or Yfr, I suggest you pick your favourite one, mark its original position (with a marker pen) then adjust it carefully. I normally adjust Yrr first. Look at the picture while you're adjusting it. If it gets worse, go the other way. On the first control find the minimum amount of sparklies you can achieve; there may still be some left. Then tackle the second control, also remembering to mark it.
      • tocold4u2
        • Dec 2012
        • 284
        • usa
        i started with the top pot ,,it didnt take much at all
          So, you fixed it ?
          • tocold4u2
            • Dec 2012
            • 284
            • usa
            yea i can now close it up for good lol i have its little brother a 42" but it just needs a set of boards n a stand!! atleast if i havd to adj it i will know now!!
            thanks for the help!!
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
