Philips Ambilight 37", strange problem
  • mcbain
    • May 2011
    • 21
    Hi everyone
    I have got this Philips LCD model 37PF9731D/10
    This tv got no picture but faint sound coming from a movie that playing from my old vcr.
    There is green power light thats stays on all the time
    I have open the tv and when the tv is on i unplugged the power feed to the mainboard and connect again the screen will light up and i got picture, but the sound stays faint. The On screen menu does not come on or i can increase the volume.
    I there is no bulge og leaking caps, no nothing visual.
    What can be wrong??
    p.s can it be the mainboard
  • janos6662000
    Philips 47PFS7509/12 LCD TV problem
    by janos6662000
    Hi
    I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
    When i applied cable signal to check image, i had normal picture, but TV was restarting.
    I downloaded original firmware and applied the update, but the problem remained.
    From a colleague i received a "factory package software" which is a lot bigger.
    I made another firmware update, but still did not solve the problem.
    Somewhere on the way the error got worse, because at the moment the...
    08-12-2025, 12:54 PM
  • Malva
    Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
    by Malva
    I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
    Mainboard model: EAX65684604
    PCB marking: EBT62954607
    SPI chip: Winbond W25X20CLNIG Problem description:
    Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
    After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
    • I bought another
    06-25-2025, 02:07 PM
  • courtcircuit
    Philips HTS8000 home cinema noise problem
    by courtcircuit
    Hello
    I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
    Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
    Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
    I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
    Removed each of tyhe boards
    02-08-2025, 08:22 AM
  • micsa84
    Mainboard problem Laptop Lenovo Ideapad 3 15ada05
    by micsa84
    Hello! I have a problem with a mainboard from a Lenovo Ideapad 3 15ada05.
    The problem is that the cooling fan is always on full speed, It doesn't recognize the battery and it is not charging it and the keyboard has only partial functionality, many of the keys don't work.
    I tried a new bios update but that didn't changed anything.
    What could be the problem with it?
    08-15-2023, 10:46 AM
  • theone111
    by theone111
    3. Problem: TV shuts down
    07-22-2024, 10:36 AM
