Viera 42 inch LCD,not firing up Looking for a bit of help ..
    Re: Viera 42 inch LCD,not firing up Looking for a bit of help ..
    Can you use diode test?
    Open diode is rare, most common is shorted.
    Diode test selected on fluke ..red to Centre lead black on outer leads
    reads 300ohms initially then value rapidly increases til Open circuit .then stays there
    til ,
    reverse the leads and the opposite happens OC down to 185ohms ish .
    this doesn't happen on the other 2 en220a's .
    does this make sense ?
    Chris
      Can you try on the diode test mode?
        can I go .. doh! and double treble doh!!!
        and go back a few messages .
        Just forget all my references to ohm .. and read .. v in diode test
        blame it on xmas stress or ongoing senility
        C
          OK, 300mV is fine, but open is not. What is the part # on the device?
            EN220a
              OK, probably this part:
              Across pins 1-2 and 3-2 you should have about 300~500; but you are saying on both you see nothing?
                it starts at 450 ish then rises to over 2v then goes oc
                its got completely differing results to the other 2 En220a diodes on the same heatsink.
                is it ok to test on the board or better to remove and test ?
                  It is better to remove in this instance.
                    its out .
                    in diode test . pos to pin 2 neg to 1 or 3 = OC
                    neg to pin 2 pos to 1 or 3 = .190-.210
                    Also taken out the other two , and these give almost identical readings
                    C.
                      Diode is good... time to look elsewhere.
                      Without a pin out of that connector it's pretty hard to figure out the on/off (pson) pin.
                        well at least they've been out to stretch their legs ..groan!!
                        The Power switch/power led/Remote IR wires all connect at this point on the main board.
                          Found this ..manual .. its uses the same Mainboard and the Wiring and connectors are the same numbers and positions.. but the power board has a different layout , but it may give some connection info .?
                          http://elektrotanya.com/panasonic_tx.../download.html
                          C.
                          Will be happy to pay for a manual if I can find exactly the right one . lots I've come across are just similar !
                            I will have a look at that.
                              even better this one ... seems very close..
                              http://elektrotanya.com/panasonic_tx-l42u10e.pdf
                              /download.html
                              has the right boards !!
                              Chris
                                Ah, well, 4 blinks on this model means A Board fault: SUB_F_12V
                                See page 56 of SM. I've copied it over to my site for easier access (ET is a pain):
                                http://www.tgohome.com/ServiceManual...&Search=Submit
                                Although it says "A Board" I am not sure, as it appears to come directly from the PSU.
                                Does the relay click when the TV turns on?
                                Check pins 4 and 5. They should change when TV attempts to power up.
                                  Relay clicks when power B pressed and clicks (off?) after the green LED blinking. and just before the 4 x blinking..
                                  Pin 5 ( tv_sub_on ?) shows 0 v all the time . no change when P but pressed.
                                  Off to take grandson to Doctors so will vanish for a wee while !
                                  Chris
                                    [QUOTE=ceedy;295108]---------------------------------------------
                                    Oops typo ..
                                    Pin 4 ( tv_main_on ) shows 0 v all the time . no change when P but pressed.
                                    Pin 5 ( tv_Sub_on) jumps to 2.53 v when P-But pressed then drops to 0v after relay clicks off.
                                      OK, so when the 2.5V comes up, you should see 12V, 17V and 24V come up. Do you?
                                      TV_MAIN_ON controls the PFC.
                                      TV_SUB_ON controls the 12V/17V/24V.
                                      If not, locate capacitor C835 near IC802. I think it will measure around 21V if it is working because the circuit near it is a 21V regulator (formed using an NPN transistor and zener diode.)
                                      If that measures 0V, check C843, which should measure a bit higher than 21V. IIf that's good, suspect the zener diode D823 or transistor Q804/Q805.
                                      The IC802 is sold as a spare part: http://richtechparts.com/i-4099-MCZ5203D.html
                                      in case that turns out to be the problem.
                                        [QUOTE=tom66;295128]OK, so when the 2.5V comes up, you should see 12V, 17V and 24V come up. Do you?
                                        Press p-But and Cap C843 goes to 18.7v then to 0v after relay clicks off.
                                          OK C843 looks good (that circuit may be used as a limiter, not necessarily a regulator.) But you are saying you get nothing on the C835 output? Check the resistance between the leads of C835. I suspect the IC has a short across Vcc and GND (which it is in parallel with.) The IC may therefore need replacement.
