Viera 42 inch LCD,not firing up Looking for a bit of help ..
  • ceedy
    • Nov 2008
    • 76
    our Panasonic TX-L-42S 10B 42 inch TV is not starting up ..
    power LED seem to be flashing a 4 Blinks Code ..
    Been told, but so far I've not been able to confirm , this refers to some Power supply problem ??
    The PSU is a TNP 8EP 101.
    I've had a peer inside for starters and the Whole PSU is visibly very clean with no Bulging Caps ?.
    Can Anyone give any help
    heres hoping ...
    Happy Christmas one and all
    Chris
    Re: Viera 42 inch LCD,not firing up Looking for a bit of help ..
    4 blinks does usually indicate a power board issue.
    Clue us in on what you have... a camera to take pictures is essential, and a digital multimeter is necessary for almost all testing.
    • ceedy
      • Nov 2008
      • 76
      hmm wot I got ???
      A brain that mostly Still Works
      Fluke meter, Weller iron , a decent Digi camera and A fair bit of Electonics kit and Capability, but a bit out of practice in fault Diagnosis, and especially in TV's & Psu's .
      But able to follow any guidelines..
      Typically I think whenever we ever have had any TV probs its always at Christmas ??
      Did a couple odd smaller LCD PSU's ( 1 Caps/trans, 1 whole power board ) last year for the kids and they are still going!!
      Chris
        Can you take some pictures of the boards inside your TV? And one of the general layout?
        • ceedy
          • Nov 2008
          • 76
          Piccy of the PSU for starters..
          C.
          • ceedy
            • Nov 2008
            • 76
            The other Board ..
            And Overall Piccy .
            Hope they are good enough ?
            C.
              Can you test the voltage on those pins on the power connector going to the AV board (with the video inputs) from the power supply board (where mains power plugs in.) Test with positive lead on each pin, negative lead on chassis.
              • ceedy
                • Nov 2008
                • 76
                Ok.. theres 23 connections .
                starting at the top ..
                Pins
                1= 0v
                2=0v
                3=5.26v
                4=0v
                5=0v
                6=0v
                7=0v
                8=0.56v
                9=0.56v
                10 to 19 all = 0v
                20=5.76v
                21=0v
                22=5.76v
                23=5.76v
                Chris
                  OK; I forgot to ask, was this in standby or powered on (attempting to power on possibly with blinking LED.) If you press the main power button on the TV, do these readings change? I can't find a service manual for this model, so I'm trying to identify possible output and control voltages.
                  • ceedy
                    • Nov 2008
                    • 76
                    This was in Powered on mode .. with blinking LED 4X
                    But the levels are the same when Off too.
                    All I get when pressing the power on switch is a relay click a moment of Power led Flashing green and then the 4x blinking.
                    I've not managed to find a wiring Diag yet either .
                    C.
                      Ah, I didn't notice there's a rigid flex connector going between the PSU and main board.
                      Do you see any other voltage changes on here when power is on/off?
                      It is definitely pointing to POWER SOS (4 blinks.) What is the part # for the PSU? Will be like "TNPAxxxx"
                      • ceedy
                        • Nov 2008
                        • 76
                        The PSU is a TNP 8EP 101. ( in the 1st post )
                        only found 1 place that can supply one of these at the moment but didn't want to jump in and buy one ( as its not cheap )
                        just in case its something else ?
                        I did the volts checks on the 23 way rigid /flexi's
                        Going to hit the hay now .. as the Light is a bit poor ( along with the eyesight this time of the evening) so will re run over the voltages in the morning .. but fairly sure there were no other variations on the 23 Rigid/flexi links) when switching on and off.
                        C.
                        • ceedy
                          • Nov 2008
                          • 76
                          back again,
                          No changes to any voltages when switching on and off..
                          The sequence is . Press power button, Relay clicks , LED Flickers green
                          for a few seconds then the relay clicks off ? and the 4x Red blinks start ..
                          chris
                          PS Found this ??? just a few bits of info maybe ?
                            I'm trying to find a service manual for this to see what the pin out is supposed to be.
                            • ceedy
                              • Nov 2008
                              • 76
                              Found a bit slightly different PSU info .. a TNp8EP103 .. the error codes for
                              this says the 4 x blinking is " sub12v_sense_SOS "
                              C.
                                Can you check the diodes on the output of the PSU transformer for shorts?
                                • ceedy
                                  • Nov 2008
                                  • 76
                                  Which exact ones do you mean ?
                                  All the diodes on the board seem ok except the component D801 ? bottom right of the PCB , right next to, and seemingly across the 250v input ?
                                  this is open circuit both directions ..
                                  Chris.
                                    The diodes on the heatsink.
                                    The "diode" across the mains should test open, it is a TVS; a surge suppressor.
                                    • ceedy
                                      • Nov 2008
                                      • 76
                                      OOps .. missed those..
                                      Just took the board off to get at them
                                      they are all En220a
                                      D835 reads different to the other 2 , centre pin to outside ones on this are open circuit
                                      the other diodes read 300 ohms ish.
                                        Can you use diode test?
                                        Open diode is rare, most common is shorted.
                                          HP ZBook Firefly 16 inch G10 Notebook Specification for Upgrade or Repair
                                          This specification for the HP ZBook Firefly 16 inch G10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 inch G10 boardview and 16 inch G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 07:20 AM
                                          09-07-2024, 07:19 AM
                                          09-07-2024, 07:12 AM
